1 - 5 of 5 Posts
Anyone know the sizes of the 2 primary radiator hoses?
I'm looking at possibly installing a Laminar oil to water heat exchanger, and would need to know the hose size for installation.
Thanks,
Thomas.
Growing up is an option
On my '04 the diameter is 1¼"
Pontiac Fanboy
Bumping this relic for 05/06 hose diameter. Can anyone confirm if it is also 1-1/4" (31.75mm) like the 04s?
I'm interested in replicating (ripping off) Stoopalini's Mocal Laminova Heat Exchanger setup in the future and need to spec it out.
Damn! I just had the hoses off on my 06. I'll be draining the distilled water and refilling with coolant. I can possibly get diameters then.
Edit: Rock Auto specs
Upper Hose:
End 1 ID - 35mm
End 2 ID - 39mm
Lower Hose:
End 1 ID - 33mm
End 2 ID - 34mm
The 04's having three hoses and the sizes do change. Cross over tube and rad holes are the same but changes for the water pump neck.
1 - 5 of 5 Posts
