41 - 60 of 79 Posts
I used the mishimoto dropped my temp almost 10 degrees and fit just fine and yes it only has a tube trans cooler but that’s cause it’s a radiator not a dedicated trans cooler but it is a 3 pass trans cooler if I’m not mistaken
Discussion Starter #43
Have you considered relocating to a cooler, less sticky part of the country??
Nah. Over my car running hot? Like pack up all my stuff and move? Probably be cheaper/easier/make more sense to put a bigger radiator in or sell the car and get something else.
Discussion Starter #44
Update fellow gto brethren. I decided just for the heck of it I would put a 180 stat in it. Didn’t think it was gonna help much, because really, what’s 6-7 degrees? Well when I took out the old old, I noticed it wasn’t installed where tab was in its notch. So upon further inspection I also noticed it was not the factory one. Motored was printed on it. And it looked like something was coming apart in it. So it was probably getting stuck. Put one I had that was given to me long ago for my truck but didn’t use it. Temps now: 190-195 in the heat of the day. I ran the piss out it (running lean too...oops) and temps climbed to 203. I can live with that. Cruise it stays 190-195...idle in traffic it stays about 195. 95f outside today and nasty humid. Still going to continue with a couple more things......and report back.
Discussion Starter #45
More info and a little update. Today was extremely hot. 93f with a 105f heat index. The air was hot. Pretty much felt like a sauna when I rolled my window Dow and stuck my hand out the window on my ride home from work. So....
Sitting idling in the parking lot at work with the hood open, ac blasting (was talking to a co worker for a bit) it was running 188. Shut the hood, 192f. So that tells me I need to make more room to get the heat out. Or maybe a cowl hood.
stuck in traffic (I have a 1 hour 26 mile commute) it would run 206f.
Cruising down the road I was at 204 and eventually dropped to 199. I noticed temps will rise when I’m not in lockup with the trans. So I need a better cooler for sure.
So to recap what o have now is
Stock aftermarket replacement radiator from 1800-radiator
Maybe a half gallon of dexcool, one bottle of redline water wetter and the rest just tap water
Cheapo tube and fin trans cooler. Not a big one either
180 stat
I’m changing the oil tonight and adding motorkote to it. Supposedly it really does reduce friction and will drop the temp. After watching project farms test on YouTube, I’m convinced it does work. I’ll report back tomorrow if there’s any change.
Repeat LS3 Swapper
180 stat
I'm in PHX, it gets up to 110+ during the summer, hottest so far was 106* and I'm still running 185-190* coolant temps around the CITY during heavy traffic in this ridiculous heat. Try a 160* thermostat with tuned fans to match, and 70/30 water/dexcool mix. A bigger rad even. Hell, a bigger rad and oil cooler is less than buying a cowl (which doesn't do anything for heat, anyway), and if you don't want a mishimoto, you can source your own cooler much cheaper. If you have a stock 05/06, look into tracspec hood vents as well.
Pontiac Fanboy
Banshee hood or heat extractors and get those fans running full time.
Repeat LS3 Swapper
And don't add anything to the oil, just run proper oil. I just went down the rabbit hole of HT/HS viscosity ratings, wear tests etc., and additives in oil lowered its performance in most tests.
Discussion Starter #49
Man I don’t like additives but this is pretty convincing. Independent test. This dude is the real deal. I’m not convinced of anything very easily.
https://youtu.be/88vwUwa3igQ
Tonight I changed my oil. And I added that additive. I’ll have temp info tomorrow, I don’t expect much of any, but I’m keeping track regardless. I will tell you this, my engine is much much quieter. My valvetrain noise is nonexistent. I never remember my engine being this quiet or smooth. I took my 15 year to to go pick up his friend tonight. He asked me why the car sounded quieter. I thought it was in my head till he asked me that. Believe me or not, no matter. I don’t believe in snake oil. Slick 50, z max etc is all crap and snake oil to me. But when you watch this guys videos, you will understand why I’m convinced.
that video doesn't really convince me of anything.
why don't you do a before and after test of the oil, with an without that additive? send them to blackstone labs or something.
Discussion Starter #52 (Edited)
Update. After changing the oil I did not noticed any real temp changes. But my Valve train and engine are definitely much quieter than usual. Coincidence? Maybe. Is it in my head? I really don’t think so because I normally can hear a good bit of Valve train under my carport and even more with the hood open. Noticed today while changing the trans cooler that it’s quieter
I ended up putting a Hayden 679 trans cooler in. It’s about twice the size of the junk one I had. I went rode around this evening. Weather is 83f super humid. Weather app says feels like 93. After several 1-2-3 and 2-3 pulls on various boost levels (was doing some tuning) the trans temp stayed around 183-183. Before it would easily hit 205-210 with less spirited driving. I even went in walgreens and left my son in the car and let it idle with the ac on just to make sure it’s sll nice and heated. It’s hot and nasty tonight. I did not like my coolant temps however. It’s 195 at cruise and I say 205-208 after beating on it. Think I’m gonna have to end up moving the cooler, changing the radiator or putting some better fans. At least I got trans temps under control but I think that’s adding to my coolant temps. We shall see during the day. I’m figuring I’ll have at least 10 degrees higher trans temps. At cruise it stayed around 172. 180-185 at cruise during the heat of the day, I can live with. I left room for a 6”- or 7” fan on the cooler. May try that next and see what I get. Here’s the cooler mounted.
Send Nudes
You don't buy into distilled water? This is why I make fun of you, because of comments like this.
Pontiac Fanboy
Man..you are so cool.
He does have a point, though.
If you're troubleshooting, cross the t's and dot the i's first.
Discussion Starter #56
Well what I’d like to know is, have you actually tested this? Or are you following along like a sheep because you read it? I’ve used it both ways, saw no difference. As much as I mess with my car, I flush the cooling system from time to time, I don’t seem to get build up. Or corrosion. Everyone is entitled to their opinion, and it’s just than until it’s proven otherwise. Not just popular belief. Hey remember years ago when people believed that smaller headers make more tq. That back pressure was needed. That backpressure made tq. Blah blah blah. I didn’t buy into that crap either. And whadduya know. They running 1 7/8 headers on little 6 liter motors now and sometimes 5.7’s and not losing bottom end. What about cylinder heads. All the bull stories you’d hear about needing small ports for tq and o don’t go to big on the heads because you’ll lose power. Then the LS1 came out and trounced those stupid ideas. I could on and on.
Here’s a good read for you. For some reason this company says do not use distilled water in your cooling system. I know I know. They are stupid and you are smarter(ass). Lol. Had too.
https://www.hyperlube.com/blog/blog/why-you-should-never-use-distilled-water-in-your-cooling-system/
Update. After changing the oil I did not noticed any real temp changes. But my Caltrain and engine are definitely much quieter than usual. Coincidence? Maybe. Is it in my head? I really don’t think so because I normally can hear a good bit of Caltrain under my carbort and even more with the hood open. Noticed today while changing the trans cooler that it’s quieter
What transmission are you running? I live around the houston area and my trans. temperature typically sits around 87F with a m6 unless there is something wrong with my sensor cause now that I think about it 87f sounds to good to be true in 95 degree weather.
If you have a m6 do you top of the tranny oil every oil change like the manual calls for? If you have a automatic I would suggest flushing all the fluid just in case.
As for the radiator I found a cheap all aluminium that cost about 150$ on amazon. I just purchased it today. My stock radiator just developed a small leak at the plastic seam. The radiator does require some trimming to the stock fan shroud as it seems due to being larger than the stock unit, however I have a procharger with the aftermarker fan shroud and extra large fans so I already have no clearance.
I contacted the seller and you can get a full refund with free shipping back if it doesn't fit.
https://www.amazon.com/dp/B06XKPV6DF/?coliid=I14IV8ZWMN6EQV&colid=3PS8JYBF5UNR6&psc=1&ref_=lv_ov_lig_dp_it
As for the motorkote I don't think that video necessary proves anything. I find it somewhat fishy why he didn't use straight up motor oil on the first test before adding the motorkote. Also there is no control group which every scientific test should have.
Also your valve train making less noise could be associated with the fresh engine oil you put in vs the older used oil you removed.
I'm not saying the product doesn't work but just that video shows no proof of it and I'm sure the guy is getting paid by motorkote to sponsor the product on his channel.
If this product does in fact reduce friction in our motors then it would also improve the efficiency and thus improve our gas mileage so I would use that as a indicator to watch for any improvement.
As for the soft water, I'm not sure how far I would look into that article. For one they are trying to sell a product and they don't provide much info on how distilled water will "eventually" destroy metal. Keep in mind "eventually" could mean 300 years. I guarantee the plastic on your radiator will crack before the distilled water ever destroys your radiator.
Also I believe the article is assuming you have just water in your radiator. Antifreeze contains lots of solutes in order to decrease the freezing point. I'm sure it contains ions that helps reduce the reaction.
Discussion Starter #58 (Edited)
I have a 4l60. Your trans stays below ambient temp? Does that even sound possible in your mind? Of course the sensor Is not right. Maybe it’s in Celsius? I mean it’s connected to a hot engine, so there’s no way the trans is that cool.
That guy is not sponsored for sure. Watch some more of his videos and you’ll understand.
My fluid doesn’t need flushing, it’s new.
The battle of wits has begun.
:mrrg: :bs:
Unless you have an aftermarket cooler system hooked up and working overtime, there isn't a CHANCE that your m6 is operating at 87ºF.
Maybe its Celsius.
87ºC = 188ºF
That's more reasonable.
180ºF is the ideal operating temp
If it is reaching 250ºF+ that's atf break down temp. = no bueno
41 - 60 of 79 Posts
