1 - 4 of 4 Posts
three rights make a left
I am having an issue with my cruise control disabling or not enabling at all when the headlights are on. No problems at all when the headlights are off. I think I have it narrowed down to the LED bulbs I have in the tail lights. My thought process is that due to the LED bulbs not being a dual filament bulb when the lights are on with the headlights, the cruise thinks that the brakes are enabled so the cruise can’t be set. Cruise also disengages when I turn the headlights on if it was engaged prior to turning the lights on. Is there a fix to this without reverting back to normal bulbs? My tail lights are tinted so I had the brighter LED bulbs in there for peace of mind with visibility. Thought about switching the LEDs out for some Sylvania bulbs.
Thoughts?
Thanks in advance.
Sent from my iPhone using Tapatalk
Known issue with the GTOs. Need to use incandescent bulbs or resistors.
one life to live...
same thing with the turn signal /
I have a different turn signal relay to prevent hyper flashing, but as soon as I use my signals, the cruise control turns off /
1 - 4 of 4 Posts
