Had a chance to do some tuning with a 2004 Pontiac GTO A4 - Magnacharged
Modifications:
Fuddle 3200 stall converter
K&N FIPK
MagnaFlow Catted mid-pipes
Custom MagnaFlow 3 muffler cat-back
90 MM TB
85 MM MAF
Bold items were added along with new supercharger housing
BLUE "BEFORE" Dyno - Custom Tune (Stock ported TB, OE MAF, Magancharger MP112 @ 11 PSI <1:1 rear drive / 2.9 front pulley>)street Tune 91 Octane
RED "AFTER" Dyno - Custom Tune (90 MM TB, 85MM MAF, MagnaVolt, Magnacharger MP122H MP122H @ 13 PSI <1:1 rear drive / 2.9 front pulley>)street Tune 91 Octane
MP112 Tuned (converter locked): 434 / 460
MP122H Tuned (converter locked): 485 / 457
67 Max RWHP increase
48 Max RWTQ increase
51 Peak RWHP increase
(-3) Peak RWTQ increase
Weather: 88-91* F / 17-21% Humidity
This is a WOT 2nd gear to 3rd gear pass on the dyno:
As you can see the minor trade off in torque is never seen in WOT 2nd, through the shift and 3rd gear (converter unlocked)
The gains were most impressive on paper BUT what really sells the upgrade is the feel. If you are a maggie owner / driver the feel is totally different. You never feel the sensation of the car topping out in the upper rpm band (5000-6500 rpm) ... it just keep pulling and pulling until the shift point. Don't forget this is a STOCK MANIFOLD car WITH CATS and a substantial exhaust system to suport street legal noise levels and interior comfort.
On a side note, some fueling issues need to be addressed at this point. The injector duty cucle is at 95% with the stock OE fuel pump and the Magnavolt. The fuel pressure drops from 60 to 50 PSI at WOT indicating a lack of volume under high demand.
Richard
Modifications:
K&N FIPK
90 MM TB
85 MM MAF
Richard
