1 - 5 of 5 Posts
04 gto cam,stall, headers
Car runs fine but at wot the car begins to stutter/ machine gun ONLY AT speeds lower than 0-30ish anything after like 50- 60 it’s fine in wot.. recently put in new maf , map, plugs & wires , also changed out the coil on cylinder 8.. checked all the cylinders by temp.. they were all running at 400F except cylinder 8 it was at 280F any suggestions?
i would check to see if #8 injector is functioning properly. A/F for that cylinder is either pretty rich or lean. check the plugs as well. i know you replaced them, but checking the condition of the plug for that particular cylinder can say a lot. It could be getting washed off by a lot of gasoline, fouled from oil, etc.
I’ll check it out again, thanks for the suggestions
1 - 5 of 5 Posts
