1 - 20 of 28 Posts
Registered Goat Abuser
Hey All – I have A-Tap on Palm that I used for the GTP. I now need to set it up for the GTO.
With this setup I had setup 5 different screens that I could monitor while underway.
For our GTO, what are the values I should be logging and what are the optimum ranges for those values?
Here is what I am planning to log, I just need to know what is the optimum ranges for each…
Value - - - - Range
Screen-1
KR - - - - 0
Ignition Timing - - - 20+
Injector Pulse Width #1 - - - - at WOT ?-?
Mass Air Flow Raw Input Frequency - - - - at WOT ?-?
Screen-2
Engine Coolent Temp - - - - ???
Transmission Oil Temp - - - - ???
Intake Air Temp - - - - As close to ambient as possible
Long Term Fuel Trim Bank 1 - - - - ?-?
Screen-3
Misfire Current Cylinder #1 - #8 - - - - 0
Engine Speed - - - - ~~
Throttle Position Angle - - - - ~~
Screen-4
Also – Which O2 Sensors should I be monitoring and what is the optimum range?
Options on my A-Tap are...
O2 Sensor - Bank 1 Sensor 1
O2 Sensor - Bank 1 Sensor 2
O2 Sensor - Bank 2 Sensor 1
O2 Sensor - Bank 2 Sensor 1 - (why 2 of the same?)
O2 Sensor - Bank 2 Sensor 2
O2 Sensor - Bank 2 Sensor 2 - (why 2 of the same?)
What else should I be logging?
Does anybody else have A-Tap on Palm? How did you mount it in the GTO?
On the GTP I used a cel-phone belt clip attached to the left center vent.
Thanks a bunch for any input you can provide this V8 newbie.
Discussion Starter #2
anybody? :confused:
Mod Hungry... Empty Wallet
You might be breaking new ground here... but you got me thinking about a new use for my Clie'
With this in place it is easy to monitor and log test runs, out on the back roads, in my never-ending quest for ‘0’ KR…
Engine Temp | LTFT
Tranny Temp | IAT
I agree... that is sweet :)
I hack cars.
On that note if anyone wants a really good deal on a used sony clie, I've got one for sale with goodies cheap :)
Just a note... I could not find a ODBII cable for the Clie, that alone stops this for me, but I would have stopped at the cost of the software... the price they want will make me go the HP Tuners route.
Are you looking for an option other than buying the EFILive upgrade for the LS1? From the AutoTap website:
EFILive Upgrades
EFILive software is optimized for GM’s LS1 engine. Highly recommended for Performance Enthusiasts with LS1-equipped vehicles!
Add EFILive Standard Edition software to your AutoTap
Model ATEFISTD $238.95
Add EFILive Professional version with bi-directional controls to your AT1 or AT123
Model ATEFIPRO $338.95
Upgrade your EFILive Standard Edition software to EFILive Pro
Model U1EFISTDPRO $100
Upgrade from EFILiveV5 to EFILiveV6, click here.
To order, write down the serial number found on the side of your AutoTap hardware and call us (815) 433 – 5100 from 8:00 AM to 4:30 PM CST.
GTPprix said:
I've got an adapter for the clie, they have em.
My searches last night were fruitless... where did you find yours?
<edit> maybe I was looking for the wrong thing... am I just looking for a serial adapter that plugs into the AutoTap connection?</edit>
I hack cars.
Huntress your looking for the right thing!! Which clie model do you have I'll try and dig one up, I found mine by looking for cell phone interface cables.
Actually I wasn't looking for the right thing... I realized this morning that maybe I should be looking for a serial cable. ;)
Thanks for offering to look, now that I am thinking straight I should be able to find it :banghead:
I hack cars.
Okies :) If you need any help and/or want your avatar back, let me know :)
A Couple of things with AutoTap. IF you select to many items to scan, it slows down it's sampling rate. So with a lot of selections, a full throttle 0-120mph run may only net you 15 - 20 lines of data vs. going with a few main items at a time, and making multiple passes. You'll net more lines of valuable data especially at shift points and at certain RPM levels.
For intance, on mine, I have about 15 things I log each time that I have in a template. Due to this, sometimes the sampling rate is slow and I'll have at WOT throttle a line of data at 4,200rpm, 5,300rpm, 5,900rpm and then back to 4,000rpm (I shifted. There are a lot of valuable gaps there that I missed due to logging so many items.
Anyway, to answer your second question, if you hit F1, A-Tap should tell you what the operating parameter ranges fall within for each item. It also is a matter of learning your car and it's preferences. I could tell you what I mine are, but you're logging a supercharged V6 car and they have different needs than a N/A V8.
Discussion Starter #15
Yea, with the Palm version of Auto-Tap I am only logging 4-8 values at a time – so I get 3-6 samples per second.
With the Palm version, I do not have a F1 key.
Ummmmmm – the S/C V6 GTP got traded 2 weeks ago for the GTO. So that is why I am now asking about the N/A V8 parms.
So please do tell me what yours are.
Ummm, since I don't live in your world, I didn't realize that you traded it two weeks ago. Ummm, from the picture posted, I see a GTP's dash.
Whatever do you use on a Palm for "Help"? F1 is generally help on a PC.
Since I don't have my laptop with me to go through each criteria you have, I don't know off the top of my head what the parameters/ranges are but I will try my best;
Screen 1
KR - don't know the range, but generally anything 2+ degrees is not good
Ignition timing - This is too variable depending on throttle position but at WOT, we're limited to 25/26*
Injector PW - Don't know
MAF Frequency - at WOT I think I see about 10 - 12k Could spike significantly though during shifts, so if you see that (not in linear relation to RPM's), it is simply an anomoly.
Screen 2
ECT - Max is 260* I believe, running 210-220*, optimum 185 - 190* (slightly cooler if increased compression from heads/cam)
Trans temp - Not sure, mine runs about 125 - 150* depending on outside temp
IAT - Idling warm should see 120 - 130*, running should be within 5 - 10* of outside temp. If you can get it cooler, all the better.
LTFT's - Not well versed on trims (as well as STFT's). I look more at the switching rates netting as close to .475mV as possible (Stoich). You can see this if you have the option to graph it as a sine curve (you can do this on a PC by hitting F7). At WOT, they should be in the high .800's to low .900's...optimum .890mV
Screen 3
Misfire Current – Cylinders 1 – 8. This is the current live misfire count. Not a history count (there is also this option). I wouldn’t waste my time monitoring this unless you are experiencing a possible misfire(s). At WOT, unless something is wrong, there should be no misfires. You will commonly see some when starting out from a stop, especially with a manual. That’s Ok. Also, AutoTap measures misfires every 200 rpm. As such, if it detects 2 misfires, it’s really 1. If it shows 10, it’s really 5, etc, etc.
RPM – we are limited to 6,250
TPA = 0 – 100%. WOT being 100%. What is also important is monitoring TP Voltage in conjunction, which at WOT should be something like 4.5 if memory serves me right.
Screen 4
We have two exhaust banks. Each bank contains two O2 sensors. 1 pre-cat (S1), 1 post cat (S2). Bank 1 (B1) is the driver’s side, B2 is the passenger side.
I think you have a typo somehow in the PCM and that duplicate is really monitoring B2S2. Not sure what is going on there.
Discussion Starter #17
WOW - thanks CMNTMXR57. Lots of good info. Now I'll digest this and come up with my 'cheat sheet'.
The cheat sheet I had for the GTP included the Ideal number and the Safe range. This way I had goals to hit while tuning. I was able to do some tuning via a Mini-AFC that allows us to fake out the computer into thinking we are getting more air so it would turn up the fuel. I just found out this may be an option for the LS1, with an adapter (but why do that when there is tuner software for the LS1).
Go Tigers!
There was a lot of information in the thread, Interesting Predator Fact.
His findings were showing considerable KR kicking in at the higher rpms.
I went out in my M6, with the Predator tune in the car, and hooked up the
diagnostics program. While making several runs I could not get any knock
retard to kick in. Zero, nada, at any rpms. Although I am happy I personally
am not getting any KR, I know others are and it's confusing. Any thoughts?
Discussion Starter #19
Hmmmm – I am really too much of a V8 newbie to be offering any advice.
What I have noticed is that on a hot day I am seeing a little KR and I am stock (little = in the .2 to 1.0 range).
I wonder what kind of KR those with the Predator stock tune had before they updated their PCM.
I also am seeing very high IAT numbers after it has sat for a few minutes after a long drive – 120-130 degrees F. That is a bummer. It seems to take a while for them temps to come back down (this is with the stock box). All that hot air can't be helping.
.2* - 1* of KR isn't necessarily bad. Most LS1's like 25-26 degree's of net timing at WOT. If you're running at 27* of overall timing, then getting 1* of KR, knocking you back to the 25/26* range, you're actually ok. My guess is that actually isn't what you're getting. You're most likely getting 18/19 - 20/21* of overall timing in reality (at least if you're IAT is killing you.
If you do a search on the IAT issue, you'll see a lot of talk about it. The IAT temp is factored heavily into the overall timing number and can scale it back drastically if it's reading a high temp.
Once you get moving, it shoudl fall to within 5-10* of the outside ambient temps.
1 - 20 of 28 Posts
