1 - 6 of 6 Posts
went to the track (motorsports ranch-houston) this weekend and beat the hella my new gears and kaaz. really pleased with the way the kaaz puts the power down - much better control of the beast now. anyway next morning i see oil that had dripped on the garage floor beneath the diff area - not a lot - maybe a couple of ounces max. so i jack er up for a thorough inspection and see (and smell) gear oil on the underbody around the differential area. I checked the level in the diff and its full - make even a bit over-full. Im thinking that the oil was forced out from the diff vent tube - and generally got splattered about the undercarriage. I think the vent tube comes out the top of the diff and just gets routed into the diff mount on the chassis (where the diff mounts bolts to the chassis) - and is permiitted to leak down / out. kind of a crappy system i think. anybody else had this happen ?
god of the sea people
well mine's in the dealer right now for a diff overhaul. the pinion and cover seal were both leaking, the rear tranny seal was leaking, and they were going to check the axle seals also. it was one-legging too.. i'm surprised they even covered it, considering i have 13k and the rear tires are almost done and don't match the front..... fronts to the rear, rears to the trash... thats what i get for being the only drifter here... i need some wheels for my adventures... so i don't tear up my stock tires, and it looks good for the dealer
Discussion Starter · #4 ·
Jontall said:
If there are no leaks; it's from the vent tube.
i cannot see any evidence that its leaking from the axle seals, the cover, or the pinion seal.
keep it simple
I had oil blow out the vent tube one time and it never did it again. The hose is pushed into the cross member that holds the rear mount.
Discussion Starter · #6 ·
yeah..what is the point in that ?? cause there is nothing to prevent it from leaking out any/everywhere. like i said..crappy design imo
i think ill install one of the home depot inline filters / catch can things and see if i can measure how much actually comes out from the vent - and when.
1 - 6 of 6 Posts
