1 - 11 of 11 Posts
Hey folks!
Over the last 1.5 years I've replaced/rebuilt the entire front and rear-end of my 06 M6 PBM with 94k miles. When I say everything I mean everything: tires, wheels, rotors, pads, brake lines, parking brake shoes/cables, wheel bearings (all four), strut mounts, struts, shocks, springs, bushings (including radius rod), inner/outer tie rods, ball joints, sway bars, endlinks, driveshaft (dss), axles (gforce), toe rod (gforce), and diff cover (harrop). The car feels absolutely amazing all around - I'm pleased with how everything turned out. Special thanks to Andy and Rob.
I had the differential rebuilt by Charles Ready as part of this refresh. Replaced gears with OEM ratio, bearings, side adjusters, seals, the works. Upon return I installed the harrop cover, filled with cheap vavoline gear oil, and re-installed the diff into the car. From there I did 500 miles of light/modest driving and then drained and filled with torco with friction modifier.
I now have ~1000 miles on the diff with several hundred miles being a track day at Thompson speedway. Before, during, and after this event I have what I would describe as drivetrain "binding". It happens randomly and I have not yet identified a common denominator but here's whats happening:
After the driveline has warmed up and always from a stop, when I accelerate slowly I feel and hear some sort of resistance in the rear like the diff/axles don't want to rotate. The first time this happened I thought something was dragging, rubbing, or the like - it wasn't. Everything is tight and torqued to spec. This issue never presents itself above a few mph. It has happened about a dozen times to date. I suspect fluid and/or friction modifier are the culprit and that I should start with adding an ounce and evaluating results. Regardless, I wanted to see if anyone here had any thoughts.
Automotive lighting Automotive tire Automotive design Automotive exhaust Vehicle Automotive tire Automotive design Motor vehicle Bumper Hood
Does it make any pops per se? Mine did leaving from stops occassionally when it was low. New fluid and fm fixed that issue
Its a deep pop, almost a thud. I've stuck a gopro in the rear on my last few drives but, of course, nothing...yet.
Discussion Starter · #8 ·
Just wanted to say damn that looks nice. That’s a nice undercarriage.
Thanks! I drive the car like I stole it but also maintain it meticulously. It's a vehicle I plan to keep it for life so its been getting a bunch of love lately to position me for the next 100k miles/15 years.
Discussion Starter · #9 ·
Update: Added an additional 2oz of type F friction modifier and have yet to encountered the aforementioned binding, no pops when doing figure-eights, two-wheel burnouts happen every time. Zing!
At the end of the day my car with the harrop cover took 3 quarts of gear oil and 4oz of friction modifier.
Hey Joegig89 your post describes my cars symptoms exactly and i was wondering what brand fluids you went with.
1 - 11 of 11 Posts
