1 - 11 of 11 Posts
Just got my car retuned at Complete Street Performance.
Major mods include:
Pacesetter longtubes
Xair intake
Thunder Racing 232/237 .590/591 12LSA cam
Fast 102
Yank PT4000
25% UDP
She feel great. We had a small issue we found after taking the car off the dyno causing the converter to slip an extra 500RPM's or so. Once we fixed that it tightened her up a good bit and likely picked up 5-10whp. Right now traction is little to nothing until 3rd in this cold weather and a 275 BFG street tire. Gonna put a MT back under her sooner than later and then look at some PRC 2.5 heads.(maybe redo the cam too)
It's nothing special but you don't often see guys posting their unlocked converter dyno's, so I figured I would share it just as a reference point. Converter slip at redline is close to 850 RPM's
Keep in mind these are numbers with an unlocked high stall, high slip converter. Lock the converter and it likely would have put down around 435-445whp.
My old setup dyno'd 381 unlocked with a smaller converter and no FAST or UDP and a K&N intake.
Is that FWD?
Major mods include:
Xair intake
Fast 102
Yank PT4000
25% UDP
Good numbers, the shop didn't print me a new dyno sheet after re-tune when they did the 3200 stall and I installed a 1 piece DSS carbon fiber drive shaft, would be interesting to see what my numbers are now.
Here was my dyno sheet after I did LS6 heads, cam, Fast 102LSXR, TB and MAF. This was before 3200 stall and CF drive shaft.
Livernois CNC Stage III LS6 heads, Stage I Cam
Cam specs, Duration [email protected], Lift .568", LSA 114
Rocker bases/pushrods, etc
Fast 102mm Intake & fuel rails
LPE 100MM MAF
105MM Accufab throttle body.
437whp 371wtq
LPE 100MM MAF
437whp 371wtq
sounds like a solid setup
Is this the place on Fern Road in West Chester Pa?
yup that's it
Made some small changes to the car, 102mm Tb and a LS3 intake.
Took it to a friends shop to clean up the tune and re-dyno. I had them pull 1 degree of timing out and slightly richen it up as I was not very comfortable with the prior tune. Fattened it up to 12.6
The dyno the car was put on is known to read lower than other dynojet 224s. ( I know everyone says that).
Car made 385whp. We decided to lock the converter and it went up to 423whp. She's a pretty hungry converter. SOTP says it picked up a bit of power and throttle response is MUCH better. We didn't even think about doing a base pull prior to swapping parts and starting on the new tune until after we were done, oh well.
Had other parts of the tune cleaned up as well and it runs much better and have much better street manners.
Feels pretty quick for a 385whp car lol. I bet on CSP's dyno with same conditions It would have made 410ish unlocked.
The battle of wits has begun.
Andrew (shop owner of CSP) has become addicted to youtube.
I was pissed because they didn't get a vid of my GTO being dyno'd!
Great numbers! Quality for price, nobody comes close to CSP.
I had the car retuned by someone else and drivability was much better with no stalling or hard starts FWIW.
Will be retuning again in a month or 2 once I get my flex fuel system all set up.
Who did your retune?
I never saw you post issues after having your car tuned at CSP?
Major mods include:
Xair intake
Fast 102
Yank PT4000
25% UDP
Did you have to do any fender work for the 275s? If not, any rubs? Thanks
Currently not rolled. Street driving I am ok but I know at the track if it can hook and squat itll rub. I did rub with stock worn suspension and only bags.
Once I roll fenders I should be golden and have no worries of rubbing.
Rear suspension is pedders 5/16 drag springs, konis, and drag bags.
Is that FWD?
I am also running 275 out back with no rubbing. I have 350mm Lovells springs and koni shocks. I also have changed all rear suspensions parts to polyurethane, including diff insert and I have no rubbing.
Ace Alloy AFF02 in black chrome
19x8.5 front 245/35/19 45mm offset in front
19x9.5 rear 275/30/19 52mm offset in rear
Running Michelin Pilot Sport 4S all around
Rims and tires are light as well.
Front rim and tire 45.2 lbs.
Rear rim and tire 47.2 lbs.
1 - 11 of 11 Posts
