1 - 15 of 15 Posts
anyone else have this problem? is it characteristic of our cars, or a problem with mine? I mean, if I am rolling, even ever so slowly, as i apply the e-brake, i get a very loud CLUNK that can be felt as well as heard. I also tend to hear at least one of my rear brakes sticking when I travel; i notice particularly at low speeds if driving alongside another car, building/wall, or something that reflects the sound back at me. The dealers are all retarted in my area, I was going to try to maybe try pulling the rear calipers and cleaning + re-greasing the slide pins and hardware.
My Holden (same IRS) would "drag" after application (the noises you hear when driving). I would gently apply the hand brake while in reverse and it would re-seat.
I reported it to the dealer and they did fix it.
Mike
No More GTO!!!!
I think they use internally mounted shoes on these cars.I'm pretty sure but could be wrong.
Why would you guys use it when rolling? It's meant to clamp the vehicle to a stop, hence the term "Emergency brake" or "Parking brake". Not a "service" brake. I have yet to have a vehicle that doesn't grab like a mofo on engagement.
Gone but not forgotten
ive only done it once or twice out of carelessness or being rushed. now i DONT do. :)
What was your hand searching for over there anyway? :D
We do..... :p
Discussion Starter · #10 ·
you mean its not there to use when my foot gets tired?
seriously, i've never driven any car where the e-brake attacks like this one does...as long as other cars are doing it, i won't worry about, at least for now. i'm going to pull mine apart and see if everything looks ok anyway..
when i said i apply it rolling, i mean less than 1 or 2 mph, literally crawling..my driveway is a steep hill, and i have learned to roll into a e-brake stop, so i know that the e-brake is pulled enough to hold my car back...it seems to set better that way anyway, ie. i don't have to yank the thing as hard as if i were doing it for a stop - its just how i use my e-brake; not to be misunderstood as my yanking it while driving down the highway...although if i did, it still should not make a horrible CLUNK as it engages; it doesn't matter how easy you apply it, once it gets to a point, its just FULL ON it seems, BANG and it engages
I've never used an e brake for anything other than parking the car. There may be somethin wrong but it seems to me like the e brake does exactly what it is supposed to do... stop the car in a hurry.
It's a parking brake. The emergency will be if you pull on it at speed.
All of the cars I've driven in the past the ebrake activated progressively. With the GTO it's either on or off, no in between.
I lost a relay or solenoid, don't remember exactly, in my '88 turbo coupe and was able to use the ebrake like the normal brake if I applied it while I had the release lever pulled. With the GTO this isn't possible. Is the GTO ebrake electronicly activated?
Discussion Starter · #14 ·
as far as i know, no, its not electrically activated - that is exactly the way i would describe it though, its on-off, like an electric brake on a trailer
Same as Mike,,, every car I've had you could lightly pull on the brake at speed and get a gentle progressive rear brake application. The GTO I test drove last week made a nice CLUNK and then clamped pretty hard, pretty suddenly (i did it going 5mph coasting to a stop in the dealer's lot).
When I'm acting a little goofy in my SVT Contour, I'll pull into my driveway, build up a lil speed, shift into neutral, then pull the parking brake a few clicks and exit the car, watching it glide to a smoothe stop. Impresses all the ladies, hahahahaaaa.
1 - 15 of 15 Posts
