1 - 5 of 5 Posts
I’ve searched far and wide for an answer and haven’t come up with anything, I’m attempting to remove the door panel on my 04. Every video I have seen shows a notch under the red indicator on the lock, used to pop the indicator, but mine has none. Anybody ever ran into this? Pics for reference.
Performance Addict
It is right here in the bottom of your picture. Use a small screwdriver to pop it out. Hopefully the arrow I drew is visible.
Performance Addict
Sorry missed that part. You should be able to use a small screwdrivers and pop it off.
wHaT a LoVeLy DaY!
If it’s not too late OP, here’s what I did. GM considered the red part a “throwaway” when fixing a door and surprise they don’t make them anymore. BUT IT HOLDS THE LOCK TOGETHER! I drilled a small hole on the long side of the red oval and then used a nut pick to pull it straight towards me.
A nut pick or any small tool with a 90 degree head. Let me know if you need help, I can take photos.
Granted it’s a month later, lol
Sent from my iPhone using Tapatalk Pro
1 - 5 of 5 Posts
