1 - 8 of 8 Posts
Well I saw how to check them. But no code is coming up. Happened today, second day with headers. I'm running O2 sims and no cats ( I know redundant statement). I popped one the other day when I forgot to plug water sensor back in :slap: but cleared that one. Now tonight another showed but no code in dash diag. Anyone know what types will and what types won't show?
Upstairs in the basement
Well why not put your AutoTap on it? Or does it not work with this car? I have been meaning to try mine out on it. Maybe I will do that tomorrow.
Discussion Starter · #4 ·
Yup I did. But I'm glad you mentioned that. I was assuming that is what was needed, and we all no what assuming does.
AutoTap will work on any GM OBDII car. I use my ancient DOS 2.5 version on mine all the time.
Well it depends on what version you have. I have the AT-1 which is supposed to be for any GM car but it will not work with a Saturn LS because they have the Opel PCM (or at least the one from a few years ago did) and it does not use the standard GM data bus.
So that is why I asked, knowing that these come from Oz there was the chance that it might not work. :)
I didn't consider Saturn normal GM. :D
I've got one of the first versions of A-tap. I started with DOS version 2.0 and upgraded to 2.5 in 1998. I've used that since. No problems whatsoever with my GTO.
1 - 8 of 8 Posts
