1 - 3 of 3 Posts
hey i have a 04 m6 gto with 45k. i have noticed a noise every since i bought the car. at first i thought it was a through out bearing but when i push the clutch in it still sounds the same. it is a rattle that i hear at idle, i can't really tell where it is coming from upper or lower part of the motor. the only thing i can think off is the rollers are loose has anyone came across this?
"Power Abuser"
Might be the fuel injecters. They are noisy from birth.
S1C:+:GTO
Or it can be the heat shield over the headers! They make a noise from time to time! Next time you start your car and the engine is cold if you still hear that noise put your hand on the headers shield and see it the noise goes away!! Before they get hot!!!
1 - 3 of 3 Posts
