Looking for the drivers side fender light socket. Does anybody know where I can get it ? GM doesn't have them.
What do you mean? You can find the little side markers lights online, clear or smoked or led. I have a set of stock oem orange ones I took off to put my clear ones on. What exactly are you looking forLooking for the drivers side fender light socket. Does anybody know where I can get it ? GM doesn't have them.
I thought I was crazy… 😂 I’m still curious what it is OP needs. The socket as in the LIGHT BULB socket that is wired to the wiring harness? That the little 194 or whatever bulb goes into!? Or the literal light housing itself. I’m confoozedYou haven’t answered the question. The only fender light socket would be the Monaro ones where the GTO badge is; which isn’t an OEM GTO part. What are you looking for?
Yea that’s what I initially said haha …i have a feeling he means the side marker lamp on the sides of the front facia.
Damn so you’re going to buy a new light socket and splice it into your harness? Or the bulb housingPBMunicorn pic is what I am referring to. The lens is fine. Its the socket the light bulb plugs into that is broken. As I mentioned earlier, it looks like the $34 Ebay one will work. Sorry for all the confusion.
Oh just saw you said the lens is fine. We’ll hope it works out for you. Might wanna check all your connections before messing with oem wiring. Make sure nothing is out of sortsDamn so you’re going to buy a new light socket and splice it into your harness? Or the bulb housing
you can use a set of rubber T10 bulb socket pig tails off of amazon. certian styles will pop in and hold.
Nice. Good to knowyou can use a set of rubber T10 bulb socket pig tails off of amazon. certian styles will pop in and hold.
I've searched every make and model under the sun. Many similar. Nothing closely matching the unique patter on the socket. Specifically the 3 shaped tabs.You might want to extend your search to imports in the junkyard for connectors and sockets.
