1 - 6 of 6 Posts
For those of you who have modded stereos with amps in the trunk.
Where did they bring your positive line through the firewall? I cant seem to find an existing hole to pass my 4 guage through.
Hoping not to drill so whatever gouge you have would be helpfull.
I'd be interested too. I'm thinking of relocating the battery to that void on the underside where the gas tank used to be. Maybe the best route is under the car.
With the hood open, look at the passenger side of the firewall. You will see about a 2"x4" oblong rubber "boot". Take a screwdriver and work your way in between the boot and the firewall. This should pry it out enough to be able to pass your wire through. I ran 4 gauge thru it, no problem. It is a rather large hole, it's just that the boot fits rather snugly.
Discussion Starter · #4 ·
Thanks Jodi..you are a life saver
1 - 6 of 6 Posts
