1 - 6 of 6 Posts
· Registered
can someone plz post pics and install instructions for the spacers they sold with the ds? were they diff mount spacers or flange spacers?
· Registered
so they are changing the pinon angle by moving the chassis to diff mount lower?? how thick is the spacer?
· Member #804
Don't belive its changing the pinion angle, it will change the driveshaft angle. However i've run chromoly 3" driveshaft then installed the spacers used a 3.5" alloy driveshaft acted the same way (in terms of critical speed).
· Registered
Discussion Starter · #5 ·
the pinion angle won't affect critial speed but vibration and u-joint life
· Member #804
1 - 6 of 6 Posts
