1 - 7 of 7 Posts
Decided to start a new thread, which also means new price for board members/affialtes only. 19k miles, original owner. Can send more pics. Email me at [email protected]. Absolute zero issues with car, i need to make room and the funds for a corvette
$19,999 OBO
Engine/Trans
Gen TTR Twin Turbo kit with GT30rs turbos
Front Mount Intercooler
317 Truck Heads
TR6 spark Plugs
Cosmetic Gasket (drops compression down a point)
Patriot Xtreme Dual Valve Springs
Chromoly Pushrods
ARP Head Studs
Custom Texas Speed Cam (have specs)
Powerbond Underdrive Pulley
Catch Can
SLP Loudmouth 1 Catback
Spec Stage 4 clutch
F body Slave cylinder
Fuel
Speed Inc Fuel Rails
Mototron 60 lb injectors
Twin in tank Walbro 255. One constant and one boost referenced
Aeromototive Fuel Pressure Regulator
-8 AN Feed line
Stock line used for return
Alcohol Injection System Methanol kit with dual nozzles and stainless lines
Suspension and Wheels/Tires
Drag bags in rear springs
KYB structs
Lovells 0 drop spring
Lovells strut mounts and bearing
Lovells radius rod bushings
Brand new General GMAXX tires all around (stock size) not even 500 miles
Alignment done by Tire and Wheel Performance in Ridgewood,NJ with specs provided by Rob at Wretched Motorsports
Electronics
A Pillar Gauge Pod with Aeroforce gauges
Team SCSS dash Pod with AEM wideband and Autometer Boost Gauge
6000k HID low beam
3000k HID fog lights
8” JL audio subs in rear deck
MTX amplifier
Trunk Mounted Battery
I Pm'd you back in March about this GTO and never heard back from you. To bad I would of loved to own it.
Have a G8 now.
1 - 7 of 7 Posts
