21 - 22 of 22 Posts
I had the same Problem.. It was the right rear wheel bearing. I could move the tire with the car jacked up top to bottom about 1/16 of an inch. It sounded normal when spun.
If the pinion bearing was sketchy and the pinion angle not corrected with the one piece install it could push it over the edge. Since it the probllem did not surface untill after the switch the logical place to start looking would be the shaft.
21 - 22 of 22 Posts
