hey i was wondering if anyone had this same problem or would know what my problem could be... i have 2 10" Alpine subs with a Infinity amp. When i put the amp in the car and run the wires to it and just get it hooked up with the ignition on the subs work fine but after i let the car sit for a few minutes with the keys out of the ignition and the go put the keys in the ignition and turn the radio on the amp will have the power light on but will not be putting anything out to the subs.. then while leaving the ignition on i will disconnect the ground or positive wire either one works and re connect it the subs will work just fine until i shut the ingnition off and pull the keys out for a few minutes.... My connections are good and the amp is getting power and the power light is on its just that it wont put out any power to the subs unitl i disconnect a wire and hook it back up... i am newer to car audio systems so i have never seen anything like this before.. please help!!
