1 - 4 of 4 Posts
I have maybe about 200 miles on my new tex clutch and i have noticed something and im not sure if there is a problem of if something is wrong. When i go to pull out gently there is a major vibrations coming from the back almost like as if a "normal" stick car is about to stall out but more violent. If i pull out agressive no problem or if i let the clutch out like normal but say around 2500 rpm instead of the normal 1000 to 1500 its also fine. Anyone no what might be the problem?????
Thanks
jason
Discussion Starter #2
Anyone????
05GTO Jason said:
Anyone????
Are your mounts in good shape? I rechecked a friend's GT because he was having about the same problem. He installed the clutch himself w/ new OEM disc and cover assy, and had the FW resurfaced and shimmed so he wouldn't have any problems. I did a tear-down to make sure it was done right. It was. Problem was with both motor mounts; he's got a heavy foot. That fixed his problem. Can't be sure about yours tho' because I'm not there.
Growing up is an option
it could be clutch chatter. when i leave off of idle i get a little. if i'm at 1,200 rpm and up i get none. chatter is something a lot of "heavier-duty" clutches suffer from. not to be too worried if that's what it is.
1 - 4 of 4 Posts
