1 - 11 of 11 Posts
· Misses the GTO
Does Hi-Temp Paint come in any color besides black? I need red for my Airbox and a couple other parts...and adventualy Pacesetters.
· Registered
Just use Krylon for plastic spray paint. I used that on my FRCs, Fuse Box cover, and radiator shroud. No problems.
· not a pontiac its a HOLDEN !!
most high heat paints , like used for exhaust parts , as the temp goes up the amount of colors drop
any exhaust parts , id use 1500 or higher , and even then they dont stay to long unless you prep them right
the air box will prob see 200-250 , because it is close to the drivers manifold/header , but most regular paints will be ok in that range as the heat is not being radiated but the part it-self
· Southside Tuner
yeah, any autoparts store should have it in any color... Ive used orange, red, silver, black, blue, clear, on past projects, its about 5.00 a can,
· Need To Drive More
Be true to the Pontiac.
NAPA also carries high temp Pontiac Metallic Blue.
Should test out high temp painted airbox this Wednesdays Fight Night.
Do it.
Do it.
that old school pontaic color should look pretty sweet on silver
Engine covers painted Pontiac metallic blue w/Grafxwerks chrome engine cover overlays.
1 - 11 of 11 Posts
