1 - 20 of 83 Posts
da slow kid of the bunch
hehe I knew you guys would rush in here.:gears:
I've got it set up to test fit them on a 05 tomorrow. I'll be taking pictures and seeing what all would need to be done to make them work. I'll post them up on Sunday
PM me for prices and contact info..
For the one's that don't know what they look like here is a link to my car on Holeshots site.
http://www.holeshotwheels.com/photo_gallery.html
I don't see any purple GTOs on there Tim... P.S. mine is an '05 and nobody called me?
???? you don't hmm I do.. and Phil's going to be out where I'm tuning tomorrow so I'll steal his car ;)
wtf? I swear it wasn't there before, maybe it was sitting next to the green light I never seem to see at the track :D. I will probably be out tomorrow too to see how Gib's car does.
so will the 15" holeshoot work with 05/06 brakes or is that what your going to find out?
Discussion Starter #8
jamesbiz said:
don't forget to post up when you do get it
thats the plan..
that's what we're going to find out.
I'm in 2nd gear so I'm well past the light you SLEEP at..:gears:
9 Second Club
I am sooo pumped about this......
Well looks like you 05-06 guy are in luck they WILL fit with a little work YOU WIL HAVE TO ROLL OR GRIND YOUR FENDER LIPS
The backs just need the brake line tweaked a little and that's all. The wheel tried on in the pic was a 15 x 9 with a 6 7/8 BS..
The fronts will either need a spacer 5/16th should do, OR grind down the caliper a little..
If you grind down the edge right above the GTO just a little they will clear fine..I'm going to find an old caliper and do it to make sure in the nexe week or two. (unless some one has done it all ready)
All Motor 11 Second Club
Great job Perdieu!
I want a set!
I have drag bags, will fender rolling still be needed? I run 17 MT 275 DRs and 18 BFG 275 DRs and no rolling is required on either GTO. I have swapped them to both cars. Both cars have bags
I assume from the above you are selling these... Please PM me a quote.
What about 16" wheels? Is that an option? Downsides?
Discussion Starter #14
OpenWheel said:
Great job Perdieu!
I want a set!
nope not selling mine but you can find some here www.holeshotwheels.com
I would still roll the lips
Discussion Starter #15
They would fit fine, but a bigger side wall tire will help more..
Does it help with grip, handling, or something else?
sidewall flex, basicly it lets the car sit on the tire patch better ( more tire hitting the ground) unless you are going for every last bit of ''hook'' a 16 will work just fine to a point
i would like prices and weights of these wheels fronts: in 16, and 17, and 16 in the rears please in the proper back space you've found
Discussion Starter #20
I've never asked about the 16" or 17" heck I don't even know if they would do them.. Most people looking for a race wheel go with 15's
Here are the 15" prices.
15x4 $239.40ea
15x8 $310.50ea
15x9 $322.20ea
BS 2 7/8 front 15 x 4 weight 8 lbs
BS 6 7/8 back 15 x 9 weight 9 lbs
heath said:
thanks for the help perdieu,im wondering if it would be possible just to order the front wheels with a different backspacing to eliminate the need for the 5/16'' spacer for those of us who dont want to grind on thier calipers
I don't think they will that would require different rim shells.
1 - 20 of 83 Posts
