1 - 4 of 4 Posts
Yellow Goat
Is the rear emergency brake on our goats a ratcheting caliper type or is it a mini-drum built inside the rotor?
KBAS
Looked at service manual... Mini Drum inside rotor.
Yellow Goat
Discussion Starter · #3 · (Edited)
Thanks a lot. I wonder how they work it then with 2 piece, aluminum hat rotors like Eradispeed. Must have some kind of steel ring insert.
KBAS
and....
"The park brake is a mechanical system. The lever is connected to the front cable. The front cable runs from the lever to the equalizer. The equalizer connects the front cable to the two rear cables. One rear cable runs from the equalizer to each rear wheel. The rear cable engages the park brake mechanism. Applying the park brake prevents the rear wheels from turning..."
:banghead: Got bored....
1 - 4 of 4 Posts
