1 - 17 of 17 Posts
Here for the Gangbang
JasonFRC was able to find my oil leak today. I have a cracked oil pan.
$315 for a replacement from the dealer.
Sigh.
Anyone aware of any aftermarket pans for the GTO?
Registered Goat Abuser
Sigh.
No Freak'n way. :banghead: What could have cracked it?
Can't you just use some of the jbweld stuff? :drink:
Jimmy
I saw one on e-bay a few days ago...zI think the seller was pick-a-part or something like that.FYI
Crankcase Oil Formulator
How on earth did anything crack your oil pan with a 15 Lb Steel Plate beneth it?
Mod Hungry... Empty Wallet
Maybe he removed it for weight reduction???
"How big could it be?"
I'm with HRJ...
Why not just get it welded? It should be no problem at all for any decent welding shop.
Discussion Starter #8
Anyone have any suggestions, then?
FYI, everyone, it wasn't cracked by an impact. I believe it was cracked by overtorquing one of the bolts.
Figured as much but thought I'd ask any way as a retorical question.
I did find a 2004 GTO oil pan on Car-Part.com for $185 from AAA Auto Parts.
Hope that is of some help.
GB=coffee pimp.
Sorry to hear that. I suppose the good news is now that you know what it is, you're one step closer to having the car back in running order.
Discussion Starter #13
Yeah - it only leaks under boost, which I've been avoiding (since the car isn't tuned).
Well, mostly avoiding. :gr_devil:
more proof that turbos are bad for you goats. maggies are better.
[/sarcasm]
At least you found out what it is. you will be very happy with it once its all done, so no fretting!
let this be a lesson for everyone else though, major projects should be done in the winter so you dont miss out on prime driving weather :(
Did you order a pan yet Mike? Or you gonna try and repair it?
Discussion Starter #15
New pan is on the way. I'm going to tap it for the oil return as well, while it's out.
Then - I'm eliminating the PCV. Or at least seriously modifying it and ditching the janky solenoid that STS provides.
Ya uh huh
Discussion Starter #17
I swear. Only a little boosties.
1 - 17 of 17 Posts
