1 - 11 of 11 Posts
Created in hatred
SW long tubes and Corsa Sport catack (no cats) all I have to say is...HOLY CRIKEY!
Noticeable power increase and an incredible sound! Need some tuning now to get rid of the popping between shifts and on deceleration.
Owns 3 GTO's
Join the club. I love the sound of my Kooks LT's, and offroad pipes coupled to my 05' split duel Corsa sport. Runs like hell. You will need a tune. Mine runs like crap now. That is, after the ses light come on. Glad you like it.
Blowed Up...
Thank God!!!
Ka-Boom!
Do you have any anoying vibrations with your SW? I cant seem to get rid of a vibration that happens every once in a while. I think the torque of the engine makes the primaries touch the steering knuckle.
Created in hatred
No vibration issues. Only issue now is the spring steel retainer on the steering knuckle bolt is rubbing on one of the primaries when I turn hard in either direction. What clamps did you use on your system? If it is those cheap ass clamp-co clamps, do yourself a favor and get rid of those ASAP, they are crap. 5 out of 7 on my system broke.
Ka-Boom!
No problems with the clamps at all, no leaks either. That was the noise I was refering to, it only does it on hard turns. I got rid of that spring clip because I basically destroyed it taking it off.
Created in hatred
You might have to tap the primary it is happening on with something. Maybe use a piece of 2x4 and a hammer and just tap it a bit to clearance it. I would check with others forst to see if anyoneelse had this issue. I figure if we doth did, then others must have had it too.
Incognito
jumpmanmb87 said:
When you guys are saying get a tune are you bringin your cars to a shop or do u have like a diablo that your using
Getting a tune usually means strapping it to a Dyno.
Owns 3 GTO's
Updated my sig with my Corsa sound clips.
1 - 11 of 11 Posts
