1 - 1 of 1 Posts
Drag racing can be very hard on the GTO driveline. The two peice driveshaft takes alot of stress on hard launches and shifts. Keep your GTO safe and NHRA legal for 12.99 and faster cars with this Drive Shaft Loop. It will accomodate up to a 3.5" driveshaft for further upgrading. Easy install without removing driveshaft. Does require welding.
Instock now @ www.ls1gtospeed.com in Black and Red
$79.99 - Click to Buy Now
BMR subframe connectors provide the ultimate in frame rigidity and add to the overall handling ability of the car. They are manufactured from 1.5" x 2" x .120" rectangular tubing and laser cut, 1/4" mounting and weld plates. The subframe connectors tie into 5 structural areas and provide 4 seperate weld points. The rear mount replaces the factory suspension cradle mount allowing full accessibility to the cradle after the subframe connectors have been installed.
$299.99 - Click to Buy Now
1 - 1 of 1 Posts
