1 - 10 of 10 Posts
hey guyzzz
i'm tryn to get a camshaft for my car
i have ls1 holden monaro A4 (like the GTO)
and my modz:kooks long headers, slp loud mouth2 cat-back system, asp pully
msd sprk plug wiers , k&n air charger , b&m trans super cooler and transgo shift kit
and ratio 3.46
and dyno tune
331wrhp
341 wrtq
i will post the sheet later
i'm tryn to make it aroun 400wrhp
note: i'm using the car every day
c ya:)
LS-WON
Check out the sponsors to the left. I know lots of LS1 owners who are running comp grinds on here from HPE or LG Motorsports. With a fairly aggresive cam and a set of heads 400rwhp is a reasonable goal. I have the LG Motorsports G5X1 cam, but you might look at the X2 or X3 which are a little larger cams and will put you closer to your goal. This has been discussed a lot on here too, so if you didnt do a search you would be doing yourself a dis-service.
CAUTION!!!!
you're gonna have to be running heads and cam to get 400RWHP with an auto. but get a good set of P&P 243 castings or better (AFR,ETP) with a cam that has around 600 lift and you could do it.
Kahuna Bill
Thunder Racing TR224 is an all around great performer in the LS1.
1 - 10 of 10 Posts
