What are the differences between the two?
Heads.... Cam....Intake?
Will parts interchange?
As far as the F-body goes I know they stopped using the smaller port LS1 block eairly 2002, or around that time. The ones built after then have the larger bay ports, LS6 block with the LS1 heads and LS6 intake.CMNTMXR57 said:LS6 block has larger bay to bay breathing ports too.
CMNTMXR57 said:That's a well known fact. The casting number for the LS6 block if you want is 12561168. You can also tell by the lister/finish on teh block. The LS6 has a less shiny/duller casting than the LS1. There are two plants that produced LS1/LS6 blocks. Montupet Canada and Nemak Mexico. When it came to producing the LS6 block, GM went with the Nemak facility.
What makes the difference in strength between the two blocks is that Montupet (LS1) uses a gravity feed process that uses a combination of metallic dies and sand cores. The Nemak factory uses a low-pressure precision fanning process.
The LS6 intake replaced all LS1 intakes by that time and did not incorporate EGR plumbing (the Vette version has never had an EGR for those that don't know) as GM utilized the ramp speeds and lobe separation on the camshaft to make up for it. To convert a NON-LS6 intaked F-Body to LS6 intake also requires a coolant bypass tube for up front and two block off lugs for the back. This is needed because the bottom of the LS1 intake has room for a coolant line to run underneath it to the back. The LS6 to make room for the additional runner size and what not eliminated this space. So you block off the back with those two lugs, and get the re-routing tube for up front. I also plumbed my factory EGR back into the LS6 intake.
We could switchCMNTMXR57 said:Someone here already has "DOG" as their's and I'd hate to steal it.
