1 - 20 of 64 Posts
It was a...
So, let me see if I can summarize the current shifter situation after using much :search:-fu on the board tonight...
STOCK
PRO: Free
CON: Frequent missed shifts, sloppy, some break
HARROP:
PRO: Shorter than stock, quasi-factory part
CON: Pricey for what it is, not that much better than stock
B&M
PRO: Simple shifter; less expensive and more quiet than some options
CON: Some leak around the trans mount, some handle breakage, be careful what version you get
HURST
PRO: Name, look, good short throw
CON: Some early failures (fixed?), noisier than expected for a remote unit, using the stock shift knob requires extra parts
GMM
PRO: Great shift quality; "street" version retains shaft damping to reduce noise somewhat
CON: Handle bolts back off / fail, rattles, "race" version can have substantial gear whine in some installs
BILLET
PRO: Adjustable, strong as an ox, remote mount so more quiet
CON: Expensive, some rattling, no product support in USA
Did I miss any other M6 shifter choices?
Growing up is an option
you missed Billet rattles problems. there's also the JHP HSV Style Shorter Shifter that is discontinued but may still be available
B&M breaks the most, like breaks in half kinda stuff.
The B&M is NOT a remote shifter, it is a direct shifter similar in concept (but not execution) to the GMM. Also regardless of version the B&M's weak point is the shaft inside the transmission, right above the ball where it narrows. That is where they often break leaving you unable to shift.
As mentioned the Billet has been reported to have some rattle issues so it can't be billed as "quiet".
The GMM is available in two versions, "race" and "street", the difference being the lever. The race version uses a solid metal lever which tends to transmit noise and vibration from the drivetrain into the cabin, while the street uses an adapter that retains the stock lever with its rubber damper section, greatly reducing NVH. Both versions use the same shifter base so the shifting action is the same, with the street version having a slightly less direct feel (although still a huge improvement over the stock POS).
The JHP short shifter mentioned is a factory part that is a much shorter version of the OEM lever and also incorporates a rubber damper section.
It was a...
Discussion Starter · #6 ·
My cut and paste fail on the B&M "remote" thing - fixed momentarily.
I'll add a bit on the two versions of the GMM.
You missed the GMM w/ the Hurst handle kit that SNL offers. I love it.
I got nothin!!!
you missed Lou's short shifter
redham's do it your self shifter shortening
ChimChim is in the HD's trunk
450+rwhp club :D
LSS + Stock is actually pretty decent and can be had for cheap. I have no real complaints and I've tried other's cars with different shifters. They all feel really tall compared to mine.
Default Title
How about adding the price of each shifter to the list .. better than just saying "hey this one is pretty expensive" :D
I got B&M and no trouble here. works great
looking to buy a shifter myself and i've had a couple questions/comments. i really like the look of the billet but as far as i can see none of their us distributors sell it anymore. also, i saw something about the rattle issues being resolved. are they?
Default Title
I ordered a Billet a few days ago directly from Billet Products. They charged around $430 (US). So (assuming it actually gets here!) lack of US distributor is not an obstacle. They mentioned it takes 5-7 working days to arrive.
thanx, i'll look into that.
The Spot Is Evil
GMM street with Lss stick and stock knob. Had it for almost three years and haven't had any issues.:gears:
Stands Alone
see...i think those hurst shifters look hideous. they belong in like a 69 camaro....not a GTO, think they'd produce something a little more modern dayish looking...i'll go with something that matches the car. thats just me though.
1 - 20 of 64 Posts
