1 - 3 of 3 Posts
5point7 said:
During regular cruising and accelleration, when viewing real time data, what type of numbers should I be seeing from the MAF?
I am also curious about this.. Can any of you tuning gods help? :hail:
They'll be all over the place. It's kinda hard to give you a "range" to be in. The numbers should be following your right foot though. If you get into it, both frequency (hz) reading and lbs/hr will increase. If you get out of it, they'll both probably spike some then go down.
The best I can say is that it'll be linear with the throttle position.
1 - 3 of 3 Posts
