Actually arent you running a dry show now? if not I would go a small dry shot, like 40-50? You could make a seperate tune, and run the right fuel mixture with it. If your going wet shot, who knows where that gas is gonna end up. My guess would be piston 7-8.ss496 said:how bad would it seriously fuk up a maggie if it was sprayed with a wet system????
gtobizman said:wet shot is a bad idea. if it backfires, you will lose your blower plus whatever other damage it does.
150 dry is a lot. make SURE you are getting enough fuel at WOT. this means get a bung welded in and monitor it. You can do it, but 150 dry shot is nothing to scoff at. not enough fuel = you buying new pistonsTechnoGeek said:Just to clarify, Use a Halo Kit 50 shot as alternative for Methanol injection when running a Maggie? (That's the long term plan).
Short Term:
Is 150 max for a dry Halo kit??
