1 - 9 of 9 Posts
donde esta la biblioteca
Does anyone know the part number to the IAT sensor on a magnuson TVS 2300??
continue reading if you would like the back story.
I had a magnuson S/C installed a few months ago and obviously tuned at the time of install. When i first picked it up after the install, the CEL light would flash at random times but seemed to happen more frequently while the car was idleing for longer periods of time.
I never really paid much attention to it because it would always shut off.
Fast forward to today, the CEL light came on and stayed on. I happened to look at my vehicle monitoring display, and it showed my IAT at 302.00F. I think I might have an issue with my IAT sensor on the S/C lol. I looked under the hood and found that the sensor hold down was actually sitting on the wire. I didn’t move it or anything yet, but it’s a funky looking sensor. I figure this would be a good place to start and see if it fixes the issues, but does Anyone happen to know the part number for the sensor??
Automotive fuel system Automotive tire Automotive lighting Motor vehicle Rim
It’s a stock GM sensor you can cross reference for a GTO. That said, you’ve got to remove the entire supercharger assembly to replace it as it’s buried inside in front of the cooling brick. Those wires you see are just passing through a bung. They travel up the inside side of the supercharger to the IAT located inside the front of the unit. Terrible design should you ever need to access it.
I actually made the same mistake your installer did when I first installed my TVS2300 on my 04. That hold down can easily snip those wires right off if you aren’t careful. I ended up relocating the sensor to that back hole like was done for the MP series blowers. You could do that too, but you would need to re-do the tune immediately as the IAT’s register higher back there than in front of the cooling brick.
Not gonna lie….sounds like a real kick to the nuts lol. I’m gonna call magnuson and the installer and see if there’s something they can do, it’s only been in the car for 6 months.
If nothing can be done what’s involved with doing this?? I’m going to try and find some posts about it but do you have any input?? Sounds like it might a be a decent project.
What’s involved regardless at this point, assuming those wires are cut, is you need to pull the head unit.
Discussion Starter · #5 ·
When you say you relocated the IAT, are you saying you relocated it to the same hole the wires are coming out, or is there a different hole??
Same hole. It fits perfectly there as that’s where it’s located on an MP series.
LOVE'N LIFE
My Maggi came with the wires pinched, only noticed it after I installed the SC and was connecting the wires, there was enough slack to putt he wires out or up enough to solder/heat shrink and push back down, works fine
1 - 9 of 9 Posts
