1 - 5 of 5 Posts
Hey all,
I'm thinking about pulling the trigger on these.
For those who have them where have you put them? I'm trying to clean up the top of my engine on my 04A4.
I've seen people use other mounts to put them on the lower side of the engine, but I have long tubes. I'm already planning on buying longer harnesses also.
just as an other option, rich tripower had posted about valve covers that basically do away with the stock coil brackets entirely, but keep them in the stock location. they look very clean. i think mr. black has them on his corvette as well.
i forget what brand sells them.
They are Holley covers. Very nicely made. They turn the coils at a slight angle for better spark plug wire routing with headers.
I painted mine body color. From Holley they come in polished, raw aluminum or black crinkle. They may have other finish choices now. They work with the LS2 coil bolt spacing but not with the LS1 coil bolt spacing though some folks have bolted on LS1 coils using just one bolt for each coil.
501454
501455
501456
1 - 5 of 5 Posts
