I am throwing no codes that I know of (atleast not any check engine light). I first noticed the car shaking upon moderate acceleration at low rpm but in a high gear. Then I tried romping on it and all the car did was misfire and backfire or pop.
So far I think I have ruled out sparkplug wires because I sprayed them with a mist of water to see spark jump and nothing. Sprayed the intake manifold and TB with brake cleaner to see a idle change and still nothing. I even tapped the MAF with the backend of a screwdriver and still no idle change. So I think my only other option would be the o2 sensors which I can't check myself or the sparkplugs themselves which are less than 2000 miles old. I also had a dynotune 2000 miles ago with a A/F that was flatlined.
Anyone with some possible options for me? What should I look for when the plugs come out? Can I tell if an o2 sensor is bad by looking at a plug? How can I tell if its the coil packs? Could this also be a valve problem or ECU problem? Thanks!
