1 - 5 of 5 Posts
Does anyone know if there is a fuse behind the outlet in the middle section of our cars. I had a phone charger plugged in a few months ago and reached back to take it out and ever since pulling it out, it hasn't worked again. I feel that I may have bend something getting it out. I checked the fuses under the steering wheel and replaced the respective one and it still doesn't work. Tested out he phone charger in my cobalt and it works fine.
Does anyone also know how to and if its easy to get into that area under the center console. I have no clue how to even get under there.
Owns 3 GTO's
You may have disconected an internal connection. I have seen some not work, and just by moving them around, then they work. A little wierd. If you can, buy a guage the uses an outlet to measure auto voltage. If it turns on, the outlet works. If not, your charged is damaged.
Former 3rd gen Camaro Driver
It only works with the key on. I'm sure you already knew that though......
1 - 5 of 5 Posts
