1 - 20 of 25 Posts
Well with mother nature and friends being tied up, I had to try. Yes they can be done in the driveway on jackstands. BUT you need a lot of height. After attempting it I wish I would have waited. But I proceeded for all you driveway guys;););):) Actually it was killing me seeing them just sit here.
Let me just say the Driver side header is the biggest pain. On a lift wouldn't be bad, but on the ground is why you need the height. Here are some pics:
Discussion Starter · #2 ·
Oh and I'm charging the Vid cam to get audio. And all I can say is..............WOW I love these. Just worried about the driver side steering rack boot, which our friends from down under had mentioned before. Pass side seems fine, but man is the driver close.
Blue Thunder
man I cant wait to hear that badboy :) How hard was it to drop that steering rack? Ill be installing mine when I get the funds together to buy em.
-Brian
Been here for a long time...
That is awful close to the boot. Maybe put some kind of shield/wrap in that one area to keep from melting it?
I like the ground clearance shot
Member #804
So did you have to totally remove the rack, or was seperating the steering shaft give you enough room.
Discussion Starter · #8 ·
Yes, they are Stainless. And You have to remove the lines to the rack and the steering shaft and drop the rack down. I did not remove the tie rods from the spindles though. That's the easy part. Tightening the lines when the header is in is a whole new ball game.
Member #804
your lucky your goat is only a few months old and probley hasn't been in snow, thoes power steering lines almost never come off without a fight, torch em loosen tighten loosen tighten torch over and over for about a 30mins. I'd image thoes lines were removed no problem?
Discussion Starter · #10 ·
Yup came off nicely. Well except for when they cracked loose and a stud went into my thumb. Explains why I have a scar there. Always the same spot on my thumb.
Upstairs in the basement
Awesome work man.... but sheesh, I had 4 open lifts today at the shop.
You should have come by :slap:
But now you know how to do them and can help me put them on my car when I get them :bubbrub
Discussion Starter · #12 ·
Deja Vu all over again;)
Autobahn Fahrer
The burned boots are a well known issue with the Aussies. I'm sure the fellows at Ls1.com.au have hit on some practical solutions.
Deuce and a Half
I am looking into headers and a cat back soon. I was wondering if anyone could recommend a good installer for the headers. I have someone with a lift and plan on doing the catback there. I just don't know if doing the headers there with out any experience to my brand new car sounds like a good idea. I live in northern NJ.
Sigo said:
Wow, I had no idea they came that close to the boots. The boots don't look like they'll last a week that close. Until I see a solution, I'm afraid that's a No Sale. :(
That boot is in a world of hurt. I'm thinking we're gonna need a Nomex wrap, asbestos, or something. Not sure if just a aluminum heat shield will handle the extreme heat that that boot can see.
Discussion Starter · #19 ·
It's only the drivers side. The Passanger side has more room. We'll see how long it lasts I guess :( Not sure what we can do about it.
Woohoo Bizarro the Guinea Pig!
1 - 20 of 25 Posts
