1 - 3 of 3 Posts
Owns 3 GTO's
HI Gene. Loking for a little help. Working on a project. Putting an LS-1 into my '99 Sonoma. I am in the process of putting on a Corvette (LS-1,6 style) accessory drive setup on the engine. I have the brakets and all the accessories. But I am not going to use "off the shelf" bolts. I want GM bolts. So below is a list of bolts I need. Was wondering if you could help me out in obtaining them.
Thanks
Main accessory braket to engine, 4 bolts.
Alternator to accessory braket. 2 bolts.
Power steering pump to accessory braket. 2 bolts.
Water pump bolts. 6 bolts.
Tensioner to water pump bolts. 2 bolts.
A/C compressor to braket, and braket to engine. 5 bolts.
Also looking for the short drain hose from the power steering tank to pump as well as the tank, mounting braket, and hardware to mount it.
Missing my little one.
Hey Kurt!
I don't know how often this section is checked by the vendors, might want to send Gene a PM if you don't get an answer in a few days.
Owns 3 GTO's
Not sure either. I'm not in a rush. But like you said, it might be a while. So I'll just copy the post and PM it to him. Thanks Ryan.
1 - 3 of 3 Posts
