Yeah I go to CSP for all my tuning needs. Looks like I need to buy HP-Tuners.
Any tips for beginners before I go out and buy it? Where should I buy it from, what should I buy, etc.
Any good documentation that won't put me in a deep coma for 8 months?
I bought mine from HP Tuners directly, I don't think they distribute to anyone else? Bought the MPVI2, did not spend the extra $$$ for Pro. Bought 2 credits so that I could tune my GTO. There is tons of stuff on the internet on howto. I learned slowly over the course of about 3 months Started with the simple stuff and added complexity. Sometimes you just need someone to walk you thru the basics in 10-15mins. Since I was born and raised in NJ (might explain a few things) I would be happy to help you get started via some phone discussion.
Step 1: Download the latest version of HP Tuner Suite from their website. You will get the VCM Tuner Editor and VCM Logger/Scanner
Step 2: Find a Stock 2004 GTO (I assume that's your year) tune that someone has posted online. Better yet I'll attach one for you to play with.
Step 3: Read that tune into the VCM Tuner Editor and start playing with it. You can do a lot of learning without spending a nickel.
Step 4: Once you purchase the MPVI2 from HP Tuners you'll be able to read the current tune from your car and start comparing it to stock to see what changes where made to convert it to SD, your tuner might even be kind enough to email you the latest tune he built for you.
Step 5: Concentrate on searching the internet on what settings need to be in the ENGINE DIAGNOSTICS section of the tune to fix your O2 trouble code problem.
Few things:
1) You can get HP Tuners from numerous vendors. Doesn’t really make a difference where though as the prices are all set by HP Tuners.
2) You really should not be tuning a car from scratch without the Pro version as you need the Pro version to integrate a wide band. Tuning without a wide band is a horrible thing to do; especially any WOT tuning. Making small adjustments via logging the trims is OK, but that’s about it.
I had excellent success tuning with a single wideband with the AEM system without needing PRO. The AEM system installs with a pigtail on the OBDII port and then the MPVI2 plugs into that. VCM Scanner reads the lambda signal just fine. Bought the AEM system direct from HP Tuners. You do need PRO if you want to read 2 widebands at the same time. Here is a screen shot of a 3rd gear pull followed by a brief 4th gear pull. Lambda is tracking real close to my .885 target.
Woah, when did that AEM system come out? I've the Ballenger Motorsports AFR500 and needed the Pro version to integrate it. I also have the older HP Tuners MVPI Pro.
Who was on Bellmore Rd yesterday at around 645 with a silver 04? I believe it had an 05 hood, and some stock 18s. Im pretty sure it was the 04 that was at Two Guys Autobody awhile back getting an 05/06 hood. I was in the TBSS.
Two pics of Devil and Olly. Olly being from the homeland of the GTO Austrailia. We met at kennedy Airport. Seems Olly ventured in visiting the colonies. He had a great time
Hey everyone, looong time member here but not active in quite awhile now. I'm definitely out of touch with the current GTO scene. My car has been neglected the last couple years so I'd like to find a reputable shop to take her in and give her some TLC. I'm located in Philadelphia area, not sure...
