1 - 3 of 3 Posts
Just a Re-engineered Cavalier
I just got my NO plate and window switch in the mail to finish the system that I have had for a week or so. I installed the solenoids on the bracket for the cylinder plate and mounted the plate and connected the lines from the solenoids to the plate. I ran the N20 line from the trunk to the N20 solenoid. Also hooked up the FPSS/Fuel line to the Schrader valve on the fuel rail and the fuel line to the soleniod, no leaks are present.
Can I run my system like this for the next week or so? I don't have the switch panel so I can't completely hook it up. So the system has no power and my bottle is closed and empty.
If not I'll just get two caps for the plate and put the cap back on the schrader valve.
Thanks everyone.
Bann3d
you can run it as long as you need this way..
you may as well run the wires to where the switch panel is going to
be and just use a toggle switch until your panel shows up
I had to run mine like this for 6 weeks until my panel came in
That's what I was thinking about doing. Dave said the panel should be in early this week. So I'm going to finish as much of the wiring as possible tomorrow.
1 - 3 of 3 Posts
