OOO I LEIK PRIZEZThen the engine may present you with a special prize.
Sorry bout that. I guess my reply got screwed up. I'm old. Anyway, back in the day, I was a Cadillac tech. The very first oil change I did on a Northstar v8 didn't go very good. 6 qts in the pan, fired it up and....No oil pressure and a whole lot of clattering. Called Tech line and the guy says," Fill the filter up! " Never had that problem again. Makes no sense to me either, but still to this day, I prime the filter firstAFAMET - did u have a question, or comment?
quoted my post, and no xtra words just curious
Oil pump doesn't get oil from the filter. It sucks it through the pickup tube into the pump, then pushes it out to the filter. Outlet of the filter goes to all the internal oil passages for lubrication.Saw this in a recent post, that I think was about something else, but showed ~9 min video of oil change, and the guy said You Need To Fill The Filter With Oil - because is 1st place the oil pump tries to get oil from. ??
have owned a lot of cars over the yrs, only blew two of em up (one a 350 in Bama after stupidly running in S in auto trans for 30 or 40 miles on I 20, and the other one, also in a 69 Firebird, ran as a Five Cylinder later - tho was told it leaked some oil out of the Big Hole in the block near the crank, go figure). Have never put oil in the filter during all those oil changes, and hasn't seemed to be a problem so far
Should I add oil to my LS1 filters in the future? To my Pontiac motors as well?
What say you?
it does. the filter takes time to fill, even if it's a fraction of a second. if you prime it, that small instance of time isn't spent filling up the filter, it's spend pushing oil through the galleys.well That's no help - you said it Makes No Diff, and you Always Do It ?
kidding
will likely put oil in the filter in future
he is right on. sump, pickup, pump, lower driver side oil galley then past that barbell to filter, filter to the oil press sensor, then lifter galleys/cam.I don't believe he said it makes no difference, only corrected the path. if the oil is picked up and then through the filter before it gets to the engine, it seems to me having the filter already full, not needing to fill it up first, before it proceeds on to the engine, that it would indeed be good if it were full first. of course, I have no idea if he was saying that.
