For those asking us for a budget-minded set of of long tube headers, your time has come! Gravana Tuning is now shipping Pacesetter GTO Long Tube Header! The painted versions are already en route to customers and the Ceramic Coated headers are coming within the next few weeks.
Pacesetter Headers Feature:
To order, please visit www.gravanatuning.com and order today to beat back-orders!
We are also offering Pacesetter's new Mid-pipe Header Extensions that allow you to simply bolt-up your new Pacesetter long-tubes to any 2005-06 GTO exhaust, OEM and aftermarket. Realize the full power of the original American muscle car by letting all six liters breathe through these specially designed mid-pipe header extensions. They slip over the Pacesetter header collectors, bolting onto all OEM and aftermarket Cat-backs for the 2005-06 GTO. Built from aluminized steel, these babies make power! Must be used with Pacesetter headers for proper fit. Will work on 2004 models if you have a 2005-06 cat-back system.
Enjoy!
To order, please visit www.gravanatuning.com!
- 1-3/4" Primary Tubes with 3" Collectors.
- CNC-machined 3/8"-thick steel flanges are matched to exhaust port profile for optimum seal and flow.
- Flash-controlled 16-gauge carbon steel primaries provide greater durability than light gauge stainless steel.
- Length and diameter of mandrel-bent tubing is optimized for flow and best performance increase.
- Tubes enter collector in proper sequence for maximum scavenging.
- O2 sensor fittings on all applications.
- Complete with necessary gaskets and fasteners for installation. Some fabrication may be required if you do not use Pacesetter mid-pipes.
- Made in USA AND Affordably priced!!!
- For Off-road use only.
- Ceramic Thermal Heat Barrier Coated or Black Painted Finish.
Enjoy!
