:secret:DevilYellow said:drunk posters are worse than a few Mustang guys.
Theres one person in this thread acting like a BOY, and he knows who he is.
:drink::drink:
you and me both.. I'm hoping for the 3.91's: What are you hoping for? Maybe we all can do a yankee swap if we winWarren said:Oh, I don't doubt that one bit. Most people have seen how bad he kicked my ass in Wichita and I haven't done anything since then. Im just crossing my fingers for the raffle prizes.....
your luck PJ you will win the camshaft kit :judge: I'll gladly accept it from you thoughsxty8goats said:you and me both.. I'm hoping for the 3.91's: What are you hoping for? Maybe we all can do a yankee swap if we win
What what what????PadreGTO said:Well, I'm officially out. Would love to meet you guys, but engine go :bomb: . Blown head gasket, glazed cylinders, or bent valves. We'll see once I take it apart. But at least this advances my next project - forged stroker kit, maybe an STS. Who knows? It'll be fun though.
Padre
Sorry to hear that Padre. Sounds like your taking it fairly well though. Doesnt mean you cant still head up this way. If you do make it up here, I'll let you take mine down the track a couple of times.. If you can drive a M6 that is??? LOLPadreGTO said:Well, I'm officially out. Would love to meet you guys, but engine go :bomb: . Blown head gasket, glazed cylinders, or bent valves. We'll see once I take it apart. But at least this advances my next project - forged stroker kit, maybe an STS. Who knows? It'll be fun though.
Padre
Hey, no worries, thanks for the offer. If you're looking for an excuse to buy a new clutch, I'd be happy to do the honors. :shiner:MRIKE2000 said:Sorry to hear that Padre. Sounds like your taking it fairly well though. Doesnt mean you cant still head up this way. If you do make it up here, I'll let you take mine down the track a couple of times.. If you can drive a M6 that is??? LOL
Take it easy
Padre
A motor is only as good as the parts in it, cheaper motors have cheaper parts. With that out of the way there is quite a bit of a comprimise going to an LS2 block in an LS1 car. First of all the cost of the valley cover, windage tray, front cover, timing set, and the few other parts needed to do a conversion. The second is the inability to run knock sensors, which is unacceptable for most people. Yes you can re-tap the block and try to fit them in around the headers and desensitize the PCM for false knock.... but its just not a easy/perfect swap.barkingspud said:Check with SDPC, they have a real nice LS2 402....
Ok so have you diagnosed what the problem is? checked compression? checked vacuum? Explain why the vavles are possibly bent (broken spring or timing chain?)PadreGTO said:Well, I'm officially out. Would love to meet you guys, but engine go :bomb: . Blown head gasket, glazed cylinders, or bent valves. We'll see once I take it apart. But at least this advances my next project - forged stroker kit, maybe an STS. Who knows? It'll be fun though.
Padre
Here's how the compression test went:GMH GTO said:Ok so have you diagnosed what the problem is? checked compression? checked vacuum? Explain why the vavles are possibly bent (broken spring or timing chain?)
Go check LS1Tech. The knock sensor issue has quite adequately been addressed. It appears the LS1 locations for the KS are drilled and tapped from the factory. People have been running sensors and getting knock and retard under the load/rpm conditions you would expect out of a LS1.DevilYellow said:A motor is only as good as the parts in it, cheaper motors have cheaper parts. With that out of the way there is quite a bit of a comprimise going to an LS2 block in an LS1 car. First of all the cost of the valley cover, windage tray, front cover, timing set, and the few other parts needed to do a conversion. The second is the inability to run knock sensors, which is unacceptable for most people. Yes you can re-tap the block and try to fit them in around the headers and desensitize the PCM for false knock.... but its just not a easy/perfect swap.
Real sorry to hear that Padre, I was really looking forward to meeting you.PadreGTO said:Here's how the compression test went:
PS-rear DS-rear
170 50
180 65
180 160
170 180
PS-front DS-front
Here's the thread:
http://www.ls1gto.com/forums/showthread.php?t=29280
I'll be doing a leakdown test in a couple of days.
Padre
Yes sir, didn't mean to start anything. There are several sponsors that build a dandy 402. I will shut up now....GMH GTO said:Heres my only issues with SDPC,
A. They arn't a sponsor of this forum
B. Their are plenty of sponsors on the left side of this page that have more expirence and longer track record then SDPC in engine building. SDPC is a Chevrolet dealership,
C.Speed inc., HPE, Thunder Racing, TSP, FLP, LPE, MTI, Cartek, EPP.
D.Most of these companies will build a LS2 motor similar to SDPC's offering for similar price built by an expirienced engine builder.
