201 - 220 of 257 Posts
3800lbs of slow
Part number for the radiator cover? My car is missing it. :(
Chicago Holden Connection
thanks!!!
VIOLET FOREVER
substitute gas cap: Stant #11839. 2 cold start cycles in the last 36 hours with no EVAP codes, in fact no dash idiot lights at all. $9.99 at Pep Boys
This is incorrect.
While it may work it IS NOT their direct replacement. That part # would be #10841 and a NAPA # of 703-1636 and a Gates # of 31843
Covers the following GM # S
10326373 10326375 10326377 10330409 10331673 10346666 10352662
10372244 10372246 10372296 10372866 10372868 15129989 15200676 15225005 15225006 22728999 96554034
Hybred Gto
this may be dumb but is there an actual parts book with all the part numbers in it. i have seen them for other cars. but can not find them for our cars...
Still a communist state
#12560961 valve rocker arm pivot support bolt
None
I need the part number for the glove box.
Parts Books
The official publisher of GM Owners Manuals, Service Manuals and Parts Manuals is Helm Inc. http://www.helminc.com There is no listing of any parts information. The only source of accurate information is the dealers Electronic Parts Catalog.:D
Registered Gator
Looking for the following Part Numbers...
1) # for the LS2 intake to cylinder head gasket (need 8 total) , I see #12580833 from a earlier post but it doesn't work...
2) # for intake manifold bolts (looks like ten total)...
3) # for MAP sensor and # for it's grommet (Helms indicates both).
4) # for plastic Pontiac Wheel center cap (my tire place tells me the msrp is over $100 - is this for one or all four. Over $400 msrp for all four center caps seems very excessive).
Thanks for your time...
Summer Tires in snow FTW
Looking for part # for door look plastic molding and red clip (door lock knob) for the driver side.
Registered Gator
I quote myself to match questions I found answers to :
1/2) Still looking for the part number for the intake to cylinder head gaskets (it takes eight of these rectangular gaskets) and the bolt numbers - Quess I'll need to drop by the Pontiac Dealership.
3) I ordered one from Gene and the grommet is included - the part number is : 16212460 .
4) I also ordered one from Gene and yes these are individually priced. One wheel cap per part ordered - so they are expensive , # is 92155956 and they are made in OZ...
Better lucky than good!
Part number for the 4 small oval keepers/guides on the block and heads.....they kinda look like mini metal toilet roll cylinders.
12577215 valve cover bolt assembly
