241 - 254 of 254 Posts
1 of 262
Automatic transmission dip stick indicator and tube (all years):
INDICATOR. Transmission Oil Filler.
2006 Pontiac GTO.
GM Part # 92057977
TUBE. Transmission Oil Filler.
2006 Pontiac GTO.
GM Part # 92159815
ACDELCO Part # 92159815 (dip stick and tube but call to confirm it's both).
1 of 262
92110275 - Transmission T56 6-speed ($6435.00)
Speaker Mounting Spacer
92046615 Left
92046614 right $5.50 each
Radiator overflow reservior parts - GENIII
92055632 - Reservoir ASM - Radiator overflow.
81046432 - Switch - Low coolant.
25099300 - Grommet - Reservoir overflow mounting.
12550385 - Stud - Reservior to wheelhouse
92057448 - Bracket - Overflow reservoir support.
92078273 - Sleeve - Reservoir support bracket stud
11094432 - Nut - Reservoir support bracket to wheelhouse
10296465 - Cap - Surge tank
92057859 - Hose - Serge tank overflow (upto L797281 12/11/01)
92111504 - Hose - Serge tank overflow (from L797282 12/11/01)
92057868 - Hose - Radiator vent
92138520 - Clamp - Radiator vent hose (Spring band)
92057869 - Hose - Engine vent
92138520 - Clamp - Engine vent house to radiator (Spring band)
92138650 - Clamp - Engine vent hose to engine. (Worm Drive)
92057863 - Hose - Surge tank to engine
92086751 - Clamp - Surge tank hose to reservoir (spring band)
92138004 - Clamp - Surge tank hose to crossover pipe.
92089709 - Clamp - Surge tank return
92138367 - Clamp - Surge tank hose to connector.
92075209 - Connector - Heater hose
92057862 - Hose - Heater return.
92138367 - Clamp - Heater return hose.
92057333 - Clip Radiator vent hose to shroud.
Rebuild Parts (LS1)
1 GM89017250 Gskt kit - cyl hd
8 GM88984247 Ring kit - pstn
8 GM92146701 Pstn & pin (56-38)
16 GM12560961 Bolt
1 GM92065825 Indicator - oil
1 GM12561544 Tube - oil lvl
1 GM12572654 Screen - oil p/up
1 GM12558760 Gskt - oil pan
2 GM12560251 Seal - inlt manif
16 GM12560744 Bolt - cyl head
4 GM12560745 Bolt - cyl head
10 GM12558840 Bolt - cyl head
2 GM12560961 Bolt
6 GM12553332 Bolt - flywheel
Clutch slave cylinder
GM92143151 Slave cyl asm
PROTECTOR BOOT 92145973 $49
GM-10456603 - Knock Sensor - $135.00 to $175.00
GM-12533587 - Intake Manifold Gasket (8) - $210.00 - $300.00
25161454 - .89c Gromet for Cruise Control Mounts (x3)
92077049 .92c - Front Strut Cap (over Strut and nut ontop of strut in engine bay)
GM-92090890 Red clips for door lock knobs .20 ea
VT/VX (and HSV) Monaro and WH - Service CD - 92145421 - $210 plus GST
VY-WK Service CD Part No: 92146909 $253.00 (trade price)
GM-92091872 - Cap-Wheel Nut (Chrome) $2.20 each
GM-10028614 plastic lock nut cap(threaded cap for the lock nut). black $0.45
1 of 262
Three Button Remote Key Head VS-VY
92049154 REMOTE KEY HEAD HOLDEN $47.85
92106801 REMOTE KEY HEAD HSV $45.65
92051573 REMOTE KEY HEAD CHEVY $47.30
92141075 Clip - Lumber $0.70 Little clip while holds the wheel for the lumber support
92141522 Button - Shift $8.26 A4 Chrome shifter button
92142530 Button - Chrome $6.99 Chrome hand brake Buttom
92135665 HDL ASM LH INR $15.81 Chrome door handle
92125660 HDL ASM RH INR $15.81 Chrome door handle
92135670 HDL ASM RH INR $15.81 Chrome door handle
92125675 HDL ASM LH INR $15.81 Chrome door handle
92141554 Mount Kit-Phone $26.50 Mobile phone mounting kit (A4 only)
92115106 Regulator FRT S $104.04 Front electric windows regulator
VT,VX & V2 coloured steering wheels
92145457 COBALT / ANTHRACITE
92145458 RED HOT / ANTHRACITE
92145459 HYPER YELLOW / ANTHRACITE
09B-021204NK GTS COUPE SILVER / ANTHRACITE
1 of 262
Drive Belt (accessories)..PN 92089561 <<<
HD Oil Filter..................PN 25014377
Fuel Filter (& bkt)..........PN 92075337 <<<
GMPP Plug Leads (red)...PN 12495519
VT II Rear Stop/Tail/Indicator harness 92146915 $25.40
VT/VX Air Flow vacuum valve 92140618 $13.70
VT/VX Green dash bulbe 92140011 $3.00
VT/VX Green A/C & Dimister buble 92142573 $3.75
VT/VX Mode bulbe 92142572 $3.95
Self Dimming Rear Vision Mirror
V2 S3/WH/WK Caprice
MIRROR ASM COMP - 10277770 $144
#92140125 - Rear seat ashtray assembly with lighter/accessory socket for VT/VX. $45ish.
LS2 parts
LS2 Engine ASM 89017654
LS2 Block 12589485
LS2 Camshaft 12574519
LS2 Intake Manifold 89017648
Intake Valve 12563063 same as ls1
Valve Springs 12586484 same as ls6
LS2 90mm Throttle Body (DbW) 12570790
LS2 Timing Chain12586482
Crank sprocket 12556582
Dampener 88958607
92067294 Cover engine manifold sight (RH) LS1 $56.65
92067293 Cover engine manifold sight (LH) LS1 $56.65
VZ
VZ BLUE TOOTH MOBILE PHONE CAR KIT
92176680 RRP $539.00
VZ Phone Connector
Plug - GM-92143075 - Connector - Phone - $2.05
Blades - GM-92141210 - Terminal Phone - $4.55 (pack of 6)
VY2 Phone Patch (Instead of above)
92175840
VZ Overhead DVD Player Kit 92176681
Maf pipe VZ WL
LS1 92067498
LS2 92067496
Manual Gear Shift Knob/shaft W/ Steel Top
Gm-92146323 Know & Shaft Red Stitching $239.39
Gm-92146314 Gearbood Red Sticthing $50.90
VZ HID Driving Lamp kit
92177442 $1650.00
VZ SS Guard Vent Stuff
92159962 Fender RH VZ SS RRP $253.00
92159961 Fender LH VZ SS RRP $253.00
92148171 Vent Asm RH VZ SS RRP $71.50
92148172 Vent Asm LH VZ SS RRP $71.50
92175663 Lamp Ind Asm RH VZ SS RRP $27.50
92175662 Lamp Ind Asm LH VZ SS RRP $27.50
1 of 262
Monaro
V2 MONARO CAI
92102689 HOSE - AIR CLEANER SCOOP
92102700 SEAL - AIR CLEANER SCOOP
92096849 DUCT - AIR INLET TO AIR CLEANER
V2 MONARO LIGHTING
92094524 MONARO HEADLAMP ASM - (RH)
92094525 MONARO HEADLAMP ASM - (LH)
92094521 MONARO LAMP ASM - REAR QUARTER (RH)
92094522 MONARO LAMP ASM - REAR QUARTER (LH)
92144534 HARNESS ASM - REAR QUARTER LAMP (2 Required)
GM-92145151 Button-Hand/brake Brushed chrome
GM-92104418 Door Handle RH Brushed chrome
GM-92104206 Door Handle LH Brushed chrome
GM-92112851 Knob, Manual Trans
GM-92094057 Boot, Manual Trans
Front bumper lower insert and driving lights:
92094526 Lamp Ass-Fog R $75 - $92
92094527 Lamp Ass-Fog L $75 - $92
92095831 Grille Front $18 - $22
92100736 Monaro Battery Clamp $3 - $5
92144535 TailLamp ASM R $83 - $102
92144536 TailLamp ASM L $83 - $102
92144534 Wiring Harness $7 - $8
Monaro Dash Cluster
92105665 - 3 Window Dash Cluster with Yellow Dials
Monaro M6 Leather Gear Boot – 92145789
Series 1 Monaro CV8 Dash Fascia
92113542 - Upper Dash Surround Piano Black M6 - $85 approx
92113543 - Upper Dash Surround Piano Black A4 - $92 Approx
92113544 - Lower Dash Surround Piano Black M6 - $??
92113545 - Lower Dash Surround Piano Black A4 - $41 Approx
GM-92112851 Monaro leather Gearknob man $75
GM-92108717 Monaro CAI Aircleaner lower bowl $20
VZ Monaro Bonnet:
92167780 bonnet $1128
92167878 r/h scoop $104.50
92167877 l/h scoop $104.50
92138798 clips $3.20 ea
92167786 Insulator $56.65
HSV
CAI
06M3990601 DUCT - AIR INLET TO AIR CLEANER H.S.V.
06M3990604 INSERT - AIR INLET H.S.V.
06M3990606 TAPE - INSERT TO AIR CLEANER (9MMX6MM) H.S.V.
06M-990603 PLUG - AIR CLEANER LOWER H.S.V.
SPLIT ENGINE COVERS
06M-990701CR COVER - ENGINE (RH) H.S.V.
06M-990702CR COVER - ENGINE (LH) H.S.V.
92176002 Cover engine manifold sight (RH) LS1 (HSV)
92176001 Cover engine manifold sight (LH) LS1 (HSV)
SPZ300167 HSV Foot pedals A4
SPZ300156 HSV Foot Pedals M6
Part No.SPZ300167 HSV A4 Pedals $142.00
HSV VX Clubsport R8
SV-E08-990605C8 R8 Decal
SV-E08-000606C8 Clubsport skirt Decal (L)
SV-E08-000607C8 Clubsport skirt Decal (R)
SV-E08-000602C8 Clubsport Bootlid Decal
SV-E08-000608C8 255 LS1 Engine ID Decal
SV-B08-020407B8 Lion/ Helmet HSV Bonnet Badge (VY)
SV-B07-000601 Clubsport Interior Build Number Badge
SV-E08-990702C8 Badge - Engine ID '300' VX GTS
92119040 5.7 Badge From Pontiac GTO
06M3990701 VX GTS DUCT - AIR FLOW METER TO THROTTLE BODY
06M3990702 - VX GTS RUBBER BOOT - (DELETES MAF).
07A010703NK - HSV Option Short Shifter, Leather Gear Boot and Knob. (kit)
GM-07A-990701 HSV Short Shift $105 (shifter only)
RH TAIL LAM ASSY (EXEC ACCEL S SS) - 92144005 - $99.00
REAR BUMPER COVER (S SS) - SV14A20000601P - $1,191.68
REAR BAR BADGE - HSV - $50 -
REAR SUSPENSION LINK - 92119830 - $315.00
TRAILING ARM ASSY - 92095194 - $405.00
DRIVESAHFT ASSY - 92109215 - $360.00
R/H/R BEARING ASSY - 92077119
RETAINER - 90425660 - $6.50
MAG WHEEL - SV10B970701 - $637.84
AERIAL BEZEL - 92034727 - $5.50
BADGE '255' - EC0800608C8 - $18.83
HSV performance brake bits (trade price ex gst)
SV-05A-970701 Front disc $487.83 (ea)
SV-05A-970714 Front bracket left $48.39
SV-05A-970713 Front bracket right $48.39
SV-05F-970702 Front brake hose left $32.37
SV-05F-970701 Front brake hose right $32.37
SV-05A-970730 Front caliper overhaul kit $31.75 (ea)
SV-05B-970701 Rear disc $447.48 (ea)
SV-05F-970703 Rear brake hose $37.30 (ea)
SV-05A-970734 Bleed screw $6.17 (ea)
GTO Engine Shields
L/H Side: IM80899 Supp Number 740603568
R/H Side: IM80898 Supp Number 740603566
Spz-300207 Hsv Power Steering Cooler Kit
HSV Accessory Wheel kits
SPZ-300050 ALLOY WHEEL SET 16X7 L (GROUP A)
SPZ-300174 ALLOY WHEELS ONLY 18X8 VT GTS1
SPZ-300174-T ALLOY WHEEL & TYRE SET 18X8 VT GTS1
SPZ-300202 KIT-WHEELS ONLY WH GRANGE CAPRI SILVER
SPZ-300202-T KIT-WHEELS & TYRES - WH GRANGE CAPRI SILVER
SPZ-300205 KIT-WHEELS ONLY-VT1 GTS-SPARKLE SILVER
SPZ-300205-T KIT-WHEELS & TYRES-VT1 18 x 8GTS-SPARKLE SILVER
SPZ-300224 KIT-WHEELS ONLY 18 x 8 VTII GTS ( CHROME SHADOW )
SPZ-300225 KIT-WHEELS ONLY 18 x 8 - SV99
SPZ-300233 KIT-WHEELS ONLY 18 x 8 - VX CLUBSPORT R8
SPZ-300233-T KIT WHEELS & TYRES 18 x 8 VX CLUBSPORT R8
HSV console drivers kit
SV-SPZ300146 HSV console kit assy $130.00 trade
