1 - 11 of 11 Posts
I've got a 04 A4 GTO that I'm trying to save and get her back on the road, the LS1 is too far gone to save and has 250,xxx miles and was abused. I want to make it a fun car to take out and have fun with (hopefully around 550-600whp eventually). I've already acquired/ bought a ARP 1/2 inch Gen III stud kit, MSD coil packs for an LS1 style head, BTR LS1 Stage 2 Truck Cam Kit ( Cam, rods, and seals), Transmission Specialties 2400-2700 stall converter, and a 4L60E PerformaBuilt transmission rated to take the HP I want. The car had 706 heads on it w/ the LS1 so it want to reuse them. Should I get new rockers, rollers, flex plate, etc... I'm younger and just unknowing. Also what are your engine recommendations for the GTO with the high compression heads in 6.0 or a stroked 6.0 that won't kill the build and stand up too a blower in the future. I would like to not touch the fuel system yet too. Thanks in advance for the advice and help.
706 heads on an ls1? Yikes. Sure some jerk didn't slap in a 5.3l?
If you are going 4" bore i would get rectangle port heads if you are on a budget. You can also send the 706 heads off for a CnC job with bigger intake valves and they flow pretty decent. If they are castec heads, throw in garbage.
It’s an aluminum block so it’s probably an LS1 and it’s the same car that had the grade 8 1/2in bolts in heads, if you remember that. Tried to save the block with some 1/2in studs but the whole right side was time serted. Don’t feel like pushing it and I just don’t think I’d be happy until it’s got at least a 6.0 in it.
They made aluminim gen iii 5.3l, engines, but i think they came with better heads. but, sae headbolts? Seriously, what the heck?
Throw engine in garbage and start over, lol.
Discussion Starter · #5 ·
Yeah at this point I’m basically going to be replacing the whole drive train. I want to feel safe about pushing the car and engine and not worrying about what else is messed up. I don’t think their castec heads but I’m not anywhere near the car so idk.
Non castec 862/706 heads are a decent basis to work with. Lots of places offer good CnC programs and valve upgrades for those heads. PRC, Advanced inductions (if you can ever get a hold of them!), TEA, list goes on.
Discussion Starter · #7 ·
This car has definitely been a headache for me. Previous owners did some very interesting things to it. What all should i look into replacing if I just buy something like a Blueprint Forged internals 6.0 short block and reused the heads just so I can start looking for some parts.
Discussion Starter · #8 ·
I would also like to keep all the parts above the heads as well, which is why I'm looking to reuse the heads or get a set of cathedral heads but plans definitely change
If you're just just shooting for 600, find a 6.0 or a 5.3 that's in reasonable shape. Put some ring gap in it, decent head gasket, studs, your cam/springs, etc... Then spray or boost it to 600. There's no need for head work other than making sure they're right. A 6.0 with a mild cam and a 200 shot will scare you for a little bit. You're going to need to do some work on the fuel system to make it safe.
Depends on how much work you wonna do overall. Getting a different gen that needs the cam and knock sensors moved and adapted, holes drilled for an alt and oil dipstick plugged. My ls6 is past saving unless I bore it out. But with machine shops being months behind and I dont wonna do alot of foot work im just getting built shot block. Bored and stroked 5.3 iron block. Gen 3 to keep my arp bolts now as they are more than enough for 700/800hp. Swapping my milled 706's over as well, gonna sell the 243's.
Id try to build a spare 5.7 my self. but if you dont mind going iron and getting one that simply drops in, wont be a bad option. Building it to last is on you, forging and balancing the internals I mean. Wont need to touch the fuel system while n/a anyway, just the injectors.
Discussion Starter · #11 ·
So I had a person whose with the car send me a picture of my heads and they’ve got the Castech battery on them. How prone are the heads to cracking. Should I to try to find a low mileage junkyard 6.0 and upgrade it in the future or is buying a pre-built 6.0 off Summit worth it in your opinions
1 - 11 of 11 Posts
