1 - 7 of 7 Posts
[email protected] TX muscle cars.
ok i have another thread going about my problem but now i have a question. does anyone know about where the pluse width and the long trim should be at like 70 mph, 75 degs.out mine is on bank one 3.2 pluse, and -9.4 give or take a little on the trim....at cruse and a flat and level road....i thought the trim was supose to be aroun 0 at cruse....my problem i am having is i am running rich sence i left the tuner, you can even smell it at the back of the car....so any opinions????
your fuel trim should be somewhere around the +-4 area
-9.4 seems you're running a little rich in that area
What are you short term fuel trims?
sounds like you're really rich then in that area.
I assume you're still in closed loop so you can't really be rich because your trims bring you back to 14.7, but they shouldn't have to work that hard.
Injectors are easier to follow if you set the software up to read % duty cycle, which is based on pulse width. If you're doing your own tuning and have a wideband, there's really not much use for LTFT, which is easily disabled. It just gets in the way.
2.7 is fine.
1 - 7 of 7 Posts
