1 - 20 of 32 Posts
Full Interior LED Kit - Pontiac GTO
At Diode Dynamics, we carry a full line of LED bulbs, to replace your map lights, license plate lights, vanity lights, trunk light, turn signals, fog lights, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not jack up the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Our LED Conversion Kits include all of the LED bulbs you need to replace the incandescent bulbs in your vehicle, for interior and license locations. It has been tested in your specific vehicle, for perfect fitment, and no guesswork! No modification is required for installation, you simply replace the bulbs!
We are pleased to offer these LEDs in a truly customized way. You can create the kit that you prefer. Simply change the quantity to "0" for any bulbs that you do not wish to purchase.
By using the ordering options on this page, you can create your own mix-and-match kit by making the proper selections on each stage, or choose one whole kit that you prefer. The product pictures are professionally taken, at the same camera settings, in order to provide an accurate idea of what the bulbs will look like, in terms of brightness compared to the factory bulbs.
Brightness. We offer three levels of brightness, or "stages." All stages will provide a sharp, modern LED look, and all include the same number of bulbs. Please be sure to read all of the following information:
  • Stage 1: Near factory brightness.
  • Stage 2: Slightly brighter than factory.
  • Stage 3: Much brighter than factory.
  • Stage 4 Flexlight: (Trunk only) This is a flexible LED strip with connector, for plug-and-play installation. It replaces your factory trunk light, and can be positioned anywhere you would like, with included velcro and adhesive.
All brightness levels are for general reference only, and apply only to the use of white LEDs. Please see the note below regarding the use of colored LEDs.
Please note that the stage 3 trunk light is often an LED board, which must be installed directly on top of the trunk light housing to achieve maximum brightness. All other lights will fit inside of the light housing with no modification. Some stage 3 interior lights use direct-replacement adapters with an LED board for maximum brightness.
Color. White is our most popular color. It is a 6000K cool LED white. We also offer yellow, green, blue, and red, at no additional charge. When making your color selections, please bear in mind that white projects the most usable light, so white will appear brighter than the same stage of a colored bulb, usually by one stage difference. For example, a red stage 3 light will have a similar usable light output as a stage 2 white light.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Need Info? Need to Order? Click Below!
Pontiac GTO LED Kit
To Order Click Below!
Pontiac GTO LED Kit
Questions? Send a PM or email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics​
pea on mea
....so just as fyi. even though the vendor here advertises
that a "full" led conversion can be had, they do not make
a led replacement big enough for the trunk light. 36mm
led is as big as they come from diode dynamics. trunk
light needs to be a 42mm led.
the trunk led option on the website needs to be removed.
Discussion Starter · #4 ·
We offer a 39mm festoon and a 44mm loop
Please give us a call if you are having issues: (314) 205-3033
We will get that fixed on the site and get you taken care of
Nick C.
i need to pick up some tails and was thinking about new front turn signals in a clear or chrome bulb. are you doing any discounts right now?
I bought your rear tail light, back up, and turn signal bulbs for my 2006 GTO. Unfortunately the smd27's aren't bright enough for me cause my tail lights are too dark. I'll be looking for when you do a special again and i'll go with your XP80's. Only negative is the bulbs turn my traction control off and keep my 3rd brake light on a lot of the time
Discussion Starter · #9 ·
The SMD27's are definitely more of a cosmetic upgrade. Feel free to give us a call if you would like to exchange them for one of our brighter options, like the HP11 or XP80: (314) 205-3033
Installing a replacement flasher module or resistors should take care of your other issues as well
Thanks,
Nick C.
There's no bending the tabs that far the stock bulb is 34mm, and if I use the 31mm Festoon bulb will it fit? i.e. the stock bulbs are the small diameter fuse style bulb.
Discussion Starter · #15 ·
Discussion Starter · #19 ·
HI, Why was my post deleted about the dome, trunk and vanity lights not fitting?
We have comparison photos with each bulb model installed in a GTO. The festoons fit. To ensure a tighter fit with festoon applications, you may need to bend the metal tabs in slightly, but that holds true for any festoon bulb.
We've sold several GTO interior lighting kits, with no reports of the bulbs not fitting. If you received the incorrect bulbs, please send pictures to: [email protected] so we can provide further confirmation
Nick C.
HI Nick, your guys are working on RMA right now for the bulbs that don't fit. That is the trunk and dome. The largest you have is 39mm and the stock bulb is 44mm. No bending tabs would help here, I'm sorry. I understand you're trying to defend the product but the product isnt the case here. It's the bulb sizes. I don't want someone else to have to go through a headache. Ronin Concealment also noted this before. If you could post the pictures of the GTO comparison I would love to see them. Thanks
1 - 20 of 32 Posts
