61 - 62 of 62 Posts
VMR v710 wheels, 18x8.5 et45 cleared the front 6 piston calipers with no spacer. It's a tight fit, but it fit.
VMR v710 rears also in 18x9.5 et50 cleared the rear 4 piston calipers.
I also have a set of 17x9.5 et54 c6 replica wheels with 5mm spacers that clear the rear wheels. Just had to tie back the brake lines for clearance. There are plenty more options for drag radials with a 17" wheel and 26" tire than 18" wheels.
Someone else can confirm that such rims are fit to the cts-v brakes without spacers?
I thought I'd add to this thread now that I've fitted the rear DBA kit to my Monaro. The factory HSV 19" wheels (below) will not clear without a spacer, although 3mm is enough.
I can't say for certain regarding either of the front kits, as I've used my own solution, but looking at the offsets of the discs used and the thickness and curve of the spokes on these wheels, I would say that spacers will be required.
61 - 62 of 62 Posts
