1 - 4 of 4 Posts
New to the group looking for some help please. Replaced my power steering pump due to bad seals Also replaced the rack for same reasons. I flushed the lines put everthing back together filled with Dexron 6 cars steers great on the lift once down it will not steer at all. Any suggestions would be appreciated or I may just burn it!
As in, the wheel won't budge, period?
You didn't mess with the hardlines that are on the rack, did you? Not the two that go in by the base of the pinion shaft housing, but the ones that go along the length of the rack.
Other than that, the only thing i can think of is the rack being bad.
If the system has air in it, pump would whine and you should still be able to turn the wheel with some effort.
Didnt mess with the lines .That bitch won't turn. But prior to that I changed just the pump all was fine till I would stand on the gas then no steering.
1 - 4 of 4 Posts
