1 - 6 of 6 Posts
I decided to run separate lines for my drag bags (left + right) and I ran out of 1/4" tubing with the kit. A few trips to hardware stores / Depot / Lowes resulted in suck-a$$ tubing that is bleeding pressure. Any suggestions on where to buy 1/4" OD tubing that wont leak?
Thx.
Beer Geek
For 1/4" ID you could try NAPA, fuel hose is usually rated to 30 some pounds. 1/4" OD is pretty small.
Thanks. 1/4" OD is what came with the drag bags. All of the fittings on the shrader valve, bag, couplers, etc are for that size tubing so I would like to find the same guage if possible.
Discussion Starter · #6 ·
vettediver said:
Call BMR they will gladly send you all you want!!
Called BMR. "NO GOOD".
Called a contractor buddy and he is hooking me up with some 120 PSI 1/4" tubing from a jobsite. :burnout:
Thanks for the responses guys. :cool:
1 - 6 of 6 Posts
